A/T owners: does your tranny go *thunk* ...
Old Jun 25, 2002 | 05:12 PM
lcf's Avatar
lcf
when you manually shift? at which shifts?
Old Jun 25, 2002 | 06:22 PM
soundmike's Avatar
Very sound, Mike
nothing here... at best i only get a hard shift (sudden burst forward) from 1-2 early in the morning when the tranny is still cold.
incidentally, just month's ago i kept complaining about a slip from 1-2. now it actually shifts hard. go figure
Old Jun 25, 2002 | 06:39 PM
SterlingMist00's Avatar
33,000 miles so far and no "thunks" yet......knock on wood
Old Jun 25, 2002 | 07:33 PM
lcf's Avatar
lcf
it doesnt go *thunk* even once in a while when you manually shift?
should i be concerned about this?
i dont manually shift often. just whenever i feel like doing a little spirited driving, like today, i was manually shifting to hit some speed to dry off excess water off the car after a carwash and my tranny went *thunk*.
hm.
Old Jun 25, 2002 | 08:15 PM
Kevlo911's Avatar
Kevlo for President
hm.
my frineds 01 gle does this too when u manuly shift from 1-2 at 6000 so it goes to 6600 it goes THUDDDD
Old Jun 25, 2002 | 08:32 PM
lcf's Avatar
lcf
it's good to see that i'm not alone.
is this *thunk* a sign that my tranny is messed up?
Old Jun 25, 2002 | 08:35 PM
SkylineGTR's Avatar
the thunk at redline...its cuz its shifting hard....and it usually happens when its JUST before redline...like almost off the rev limiter but not.....but other thunks i dont have reason for....cuz when i manually shift at redline....if i get it perfect...like the instant before rev limiter i get that thunk.
Old Jun 25, 2002 | 08:50 PM
[maxi-overdose]'s Avatar
Re: A/T owners: does your tranny go *thunk* ...
I tried it today....not here....and my first tiem manually shift my car too.
Old Jun 25, 2002 | 08:53 PM
Ludacris's Avatar
Mine does that and I'm not even manually shifting. Sometimes I'll get on the gas and see some brake lights, let go and get on it again and at that moment it'll hesitate and thunk.
Old Jun 25, 2002 | 09:02 PM
IWNTMORHP!!'s Avatar
CAN YOU PUT IT ON THE WALL?
yeah i have it big time. down shifts occassionally, and definitly right at redline, also on a drop to 1st or 2nd and a jump on the throttle(love the power on the down shift) *probably not the most advisable thing to do but...its what i do
Old Jun 25, 2002 | 09:38 PM
2001SE's Avatar
downshift to 1st from low speeds is really noticable. it quite bothers me, is it somethign wrong with the gear? cuz its such a harsh downshift, every passanger in the car needs a neck surgery after it
Old Jun 26, 2002 | 12:42 AM
2K1HoMax
u got it perfect then, i had the sme problem, its just timing if u get it right i will pull all the way to 6600rpms and jsut go into the next gear and run hard to redline again. but if u slightly pass is yeah it goes thunk as well. i was told by some1 that it was wheelhop or something but i dont think so.
Old Jun 26, 2002 | 03:22 AM
Tony Fernandes's Avatar
Nope.
Tony
Old Jun 26, 2002 | 09:27 AM
Maximam's Avatar
The thuddd is from the car hitting rev limiter then as the revs drop below limiter the motor coming to life again. I have done it when manually shifting and it is one of the worst feeling/sounding things, it is not good for your car.
Old Jun 26, 2002 | 10:01 AM
Themaxidocius's Avatar
There is a TSB for 5th Gen maximas with A/T. Nissan ****ed up the A/T and you have to get it fixed. Look in TSB post.
Old Jun 26, 2002 | 10:05 AM
Here is the TSB
http://www.punkdork.net/max/tsb039a.pdf
Old Jun 26, 2002 | 10:09 AM
The link isn't working
The above link I got from the Technical Service Bullentin Post it is the second post there.
But it must be very outdated. Maybe someone has a link to th 5th gen A/T auto slippage they can post that results in this *thud* everyone is guessing about.
Old Jun 26, 2002 | 11:13 AM
Kevlo911's Avatar
Kevlo for President
usualy if u shift at 5700 rpm it won't do it 5800+it goes "thunk"
Old Jun 26, 2002 | 11:16 AM
Texasguy's Avatar
My transmission sucks. It is crazy...during 10-15MPH going thru parking lots it can't F'ing decide what gear it wants to be in. Then, it will just down shift and surge forward making me look like an *** with people in the car. I approached two dealers about the issue and they said its 'normal'. Normal my ***. I just will never get an auto tranny again....well, until I get my new MB 500SL
JSpecMax's Avatar
Thunk only when shifting from 2nd to 1st at speeds above 5 mph.
Old Jun 26, 2002 | 12:50 PM
lcf's Avatar
lcf
this is also true for my tranny.
when i manually shift it right before redline... it goes:
*thunk*
catches the gear.
*i speed off*
i suppose if everyone elses car is behaving the same way... it's okay?
Old Jun 26, 2002 | 01:03 PM
Neal728's Avatar
Maybe this has been said already in this thread, but if you want to shift @ redline, just get the manual tranny. Automatics are not made for that, @ least the Maxima's isn't, as you can tell.
Old Jun 26, 2002 | 01:07 PM
lcf's Avatar
lcf
are you saying that A/T maxima owners have no right to go to the track?
because the maximas A/T wasnt "made" to be manually shifted?
Old Jun 26, 2002 | 03:09 PM
no choice the wife wouldn't learn to drive manual! ****ed me off royaly, but had to have a vehicle we could both drive. just the way life goes.
Old Jun 28, 2002 | 09:33 PM
scmaxima2k's Avatar
i think that thud is because when it shifts the tranny doesnt go right into gear so the rpms are up and then it catches causing a little surge kinda like a neutral shot. this automatic sux and i really wish i got a 5 speed. now that its humid out around here, my tranny shifts mint. it must like this humid weather....but i dunno
Old Jun 28, 2002 | 11:19 PM
Menasor's Avatar
This has happened to me twice during manually shifting my car. Darn auto is just slow, at least for my taste. It doesn't seem the same anymore. My question is what is happening internaly in the transmission when it "thunks." Has anyone had their car fix. I mean had the dealer fix what is described in the TSB?
Old Jun 28, 2002 | 11:59 PM
8702's Avatar
any 2k2's with this "thunk"?
MaxStock
Dec 5, 2016 05:19 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
