Fresh Alloy reports 290 hp out of VQ35
Old Jul 15, 2002 | 11:43 AM
  #161
AltyPaul's Avatar
Carpoint isn't known for accuracy. I would double-check the ESM.
Originally posted by ewood420
Check this link out. Seems the bore & stroke is different too.
http://carpoint.msn.com/compare/choo...0135&pt=compet
Old Jul 15, 2002 | 11:45 AM
  #162
soundmike's Avatar
Very sound, Mike
I didn't know they'd be different. But to answer your question:
SEFI: Sequential (E?) Fuel Injection
MPFI: Multi-Port Fuel Injection
Old Jul 15, 2002 | 11:52 AM
  #163
AltyPaul's Avatar
I don't know if the 2 terms are synonymous.
http://www.howstuffworks.com/fuel-injection4.htm
There are two main types of control for multi-port systems: The fuel injectors can all open at the same time, or each one can open just before the intake valve for its cylinder opens (this is called sequential multi-port fuel injection).
The advantage of sequential fuel injection is that if the driver makes a sudden change, the system can respond more quickly because from the time the change is made, it only has to wait only until the next intake valve opens, instead of for the next complete revolution of the engine.
Here's another source on fuel injection.
http://autos.yahoo.com/repair/results/ques075.html
Old Jul 15, 2002 | 12:17 PM
  #164
SR20DEN's Avatar
VQ Wizard
HAHAHAH.. Carpoint dumbasses. The geometry listed for the 350Z is for the VQ30DE. ALL VQ35DE's are 95.5mm bore x 81.4mm stroke. Thats roughly 3.76" x 3.2". The VQ30DE is 93mm x 73.3mm.
I am not sure about the fuel rail and injectors. It stil seems to me that all VQ35s have virtually the same fuel rail. And you can count on the injector bosses being in exactly the same spot with the same gaskets.
Old Apr 25, 2006 | 08:07 AM
  #165
DeusExMaxima's Avatar
Originally Posted by 02MaximizedVQ
I doubt the ECU from the 350 will be able to be used on the Maxima. The fuel pressure is probably higher and the injectors may be larger too. Also the CVTC is programmed for use with longer duration higher lift camshafts which could also be a problem for us Maxima owners.
Jesse
My ECU has been reflashed with the 350Z program in it and its fabulous!!!
Old Apr 25, 2006 | 08:12 AM
  #166
Stardust's Avatar
F---ing Kangaroos
Why on earth did you bring this back after 3.5 years?
Old Apr 25, 2006 | 08:26 AM
  #167
Blackwind's Avatar
ban his ****!!!
Old Apr 25, 2006 | 08:55 AM
  #168
nice95GLE's Avatar
What a suprise to check my email and see "Reply to post 'Fresh Alloy reports 290 hp out of VQ35'..."
Old Apr 25, 2006 | 12:40 PM
  #169
knight_yyz's Avatar
Toolie
http://www.bishopsales.com/cosworth_racing_nissan.html
this probably put out over 300 HP, but just a guess
mclasser
22
Nov 12, 2020 01:58 PM
mkaresh
Mar 12, 2018 06:48 PM
gigabyte
Jan 6, 2017 06:05 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
zmcneely13
Sep 26, 2015 02:26 PM
