Adding amps to a Bose system
Old Feb 29, 2004 | 01:24 AM
cobymoby's Avatar
Hi seen a lot of people here asking about how to add a sub to the Bose stereo without using hi-low speaker level converters.
Use the PAC adaptors. They convert the OEM balanced line level signal to an unbalanced RCA line level signal before the OEM Bose amp. The unit plugs right in between the factory head unit and the factory harness with it's own male/female harness. There is no cutting or splicing involved, just plug and play.
We are an authorized PAC dealer and ALWAYS keep these in stock. You could order them a most audio shops but they charge an arm and a leg for these. Or buy direct from us.
Regards,
Bryan
bryan@berktechnology.com
Old Feb 29, 2004 | 01:44 AM
kito2112's Avatar
Thanks for the info. I think the Bose system in the '04 need a little kick in the pants.
Can you give me a link?
Old Feb 29, 2004 | 09:07 PM
rabenoja's Avatar
Does the plug install behind the radio or at the bose amp?
Old Mar 1, 2004 | 02:56 AM
cobymoby's Avatar
behind the radio. here is a pic on my 5th gen w/ Bose. No cutting or splicing, just harness.
Old Sep 2, 2008 | 01:40 PM
BAD2THAMAX's Avatar
what if i want to use the hi/lo converter do i have to tap at the rear speakers after the amp or i can tap it anywhere before the amp? i had it behind the dash before and the amp was pounding my 12's but it didnt get deep.... so i asked a local shop and they said that the stock HU is weak thats why it needs stock amps to push the system. which means weak signal going to the hi.lo converter which sends signals to the amp... please let meknow if i have to by-pass the amp or not? thanks
Old Sep 2, 2008 | 02:37 PM
KCMAXX's Avatar
KC's FINEST
Try checking the Audio/Video section...
I doubt you'll get too many easy replies bumping 4 year old threads.
Dosen't sound like me at all.
Old Sep 3, 2008 | 09:22 AM
Levissan's Avatar
^^^^What he said. Plus if you kick up the amps on a bose system you will blow the hell out of it. Sounds good for a while but then you will hear the snap crackle and pop of the true Bose..............no highs, no lows, must be bose
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
Need help
23
Oct 2, 2015 08:56 AM
popdedop
Sep 11, 2015 11:17 AM
