Remote starters
Old Jan 5, 2005 | 04:47 PM
froMax's Avatar
Remote starters
Looking for info on remote starters and where to find an experienced w/Max tech to do it. All I know is that a guy at work said get a Viper. Thanks...
Old Jan 5, 2005 | 05:04 PM
install30's Avatar
I work for all the dealerships here in Charleston and install all the mobile electronics...well actually I have guys who do it for me now....when it comes to remote starts, DEI (they make viper,automate,hornet wasp,etc.....) make the best products. Most installers will agree with me. Find a reputable shop (ie Bestbuy, Circuit City....) and have them install one for you.....it's really not to hard to install just as long as you know what you're doing. DO NOT GO TO NISSAN TO GET THIS DONE BY SOME TECHNICIAN WHO DOESN'T KNOW MUCH ABOUT REMOTE STARTS.
Old Jan 8, 2005 | 07:19 PM
mr.b's Avatar
I agree. I would avoid the dealership unless needed. I used to work at Circuit City for about 7 years doing stereos and alarms. I have had my 1996 4Runner with a Viper 550 on it for 8 years. The truck has only failed to start 1 time since I installed it. I plan on getting a new DEI product when I pick up my new Maxima in March or so. The whole line has changed so much over the years I can't speak for anything but the brand. You won't be disappointed with a DEI product.
Old Jan 10, 2005 | 08:19 AM
bigcozz's Avatar
What about all of the problems they were having installing the remote starters and alarms in the 04. werent people having problems with the power door locks burning out?
Old Jan 11, 2005 | 12:07 AM
jsmithsole's Avatar
*moderator*
install30 has the best advice, get it installed correctly, you don't want any problems down the road. I've had mine for over a year with no problems...
By the way I have the Clifford Matrix 3.5RS
Here's a thread with a bit more info:
http://forums.maxima.org/showthread.php?t=363281
Good luck!!
Old Jan 11, 2005 | 03:40 PM
install30's Avatar
Good luck!!
Thanks...just make sure whoever does the remote start knows for sure what he/she is doing. MECP certification doesn't really make a difference....true hands on training and good experience should be a good start.
Old Jan 15, 2005 | 04:26 PM
froMax's Avatar
I found a place on Broadway in my neighborhood that had a Valet 561T (DEI) for $180 installed with the bypass module and the anti-grind module.. They said they could program my factory key fob to do the starting and not lose any of the functionality of the Nissan fob. I wanted to continue to be able to do the windows down and the trunk pop with the fob. When you go with the aftermarket brands and use their fobs, you have to add modules for most of the additional functions. I figured keeping the Nissan fob was the best way to go.
So, I picked up my Max and drove off to pick up a few things at Osco. I came out of the store and hit the remote start. The car started fine and then I tried to pop the trunk. Nothing. Ditto for the windows down function. I turned the car off and tried to pop the trunk, and it worked like usual. WTF? Back to the shop and they told me this was a safety feature. The tech demonstrated that even when started normally with the key, if you tried to pop the trunk with the fob (while the car is running), it won’t work. They told me I have 3 options: open the trunk with the fob, and then activate the remote start (not always safe), remote start the car, shut it down, pop the trunk, remote start again (too low-tech for me), or remote start, open the door, pop the trunk from inside, and then go back around to the trunk (too much movement). They’re going to check to see if there’s a module available to bypass the “safety” function.
Old Jan 15, 2005 | 04:30 PM
maxxoutt's Avatar
I Got The Prestige Remote Start Pager.it Works Pretty Good.had No Probs.
Old Jan 15, 2005 | 04:42 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
hey maxxoutt fix you're sig so at the end it has [/img] instead of [img] so you're sig shows........
Old Jan 16, 2005 | 09:52 AM
nyautostyle's Avatar
i havent had the chance to install a RS on the newer maximas, but there really is a safety feature? i never came across this, my roll down, pop truck still works on my max wit the remote start. how did he program it, with a new remote or stock? double lock or what?
Old Jan 16, 2005 | 11:27 AM
rabenoja's Avatar
Well, I would suggest asking them to upgrade you to the 562T. It is a remote start system with keyless entry. It has an aftermarket key fob but, you can get all of the features that the factory one has. The window roll up and trunk pop are very simple add-ons. All the installer has to do is hook up the wires, there is no need for an extra modules. While the installer is there though, I would have him hook up the window roll down feature on the DEI remote. So, you would actually have more features with the DEI remote than the factory one. PLUS, you get better range with aftermarket remotes. GOOD LUCK.
Old Jan 16, 2005 | 12:32 PM
froMax's Avatar
Thanks. I'll see if he can get that model.
Old Jan 16, 2005 | 12:44 PM
froMax's Avatar
Then again, maybe I haven't made myself clear. Ok. Here's the drill: start your car normally with the key. Press the trunk button on the fob. It won't work. This is the safety feature--designed so that we don't accidently pop the trunk while in motion. Now, shut the car off. Start it with the remote starter. Try to pop the trunk with the fob. Same safety feature comes into play. Frankly, I can't see myself accidently pushing the trunk or any other button on the fob while in motion. Nissan: protect us from ourselves?
Old Jan 17, 2005 | 11:53 AM
bigcozz's Avatar
Whats the best palce to go in the NYC area? For a remote start with pager or a high end clifford system.
Old Jan 17, 2005 | 05:58 PM
rabenoja's Avatar
Yeah, I figured that's what you meant. With the DEI remotes you can still use your trunk pop and other features while the car is started. I figured that is what your after.
Old Jan 17, 2005 | 06:07 PM
froMax's Avatar
However...the DEI remotes won't do the window down function. So, after living with the RS for 2 frigid days in Chitown, I think I'll adjust to having to pop the trunk b4 I do the remote start. Now if only I can get the fob to swing open my side garage door...
Old Jan 18, 2005 | 08:30 PM
rabenoja's Avatar
yes, the DEI remote will do the window down function. You can also add the window up to the DEI remote. If you have the door locks hooked up then, all your installer has to do is extend the pulse on the door lock wires to control your windows.
But anyway, if you are happy with what you got then that's cool.
LOL, on the garage door. I won't even get started with that.
Old Jan 19, 2005 | 12:18 AM
jonniewaka
i got one of these from ebay..would this be ok for my maixma i bought all the modules that was an option to add inthe listing..
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Old Jan 19, 2005 | 05:46 AM
bigcozz's Avatar
HAs anyone had a problem with their remote start in the extreme cold. i have had them on past cars and when it got really cold like it has been in the northeast in the past few days the car would crank but not start all the time.
Old Jan 19, 2005 | 07:32 PM
rabenoja's Avatar
Make sure that you have your tach connection hooked up. You shouldn't have a problem if it's hooked up right.
Old Jan 19, 2005 | 09:04 PM
yes... tach wire
How to find a tachometer wire with your multimeter:
1. Set to ACV or AC voltage (12V or 20V is fine).
2. Attach the (-) probe of the meter to chassis ground.
3. Start and run the vehicle.
4. Probe the wire you suspect of being the tachometer wire with the red probe of the meter.
5. If this is the correct wire the meter will read between 1V and 6V.
(It should increase and decrease with the vehicles rpm)
just some info...
Old Jan 20, 2005 | 06:28 AM
bigcozz's Avatar
Thanks guys !!! i still have to find a good shop.
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
ToTheMax305
Sep 23, 2015 09:11 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
