squeeking when going over bumps
Old Jul 25, 2005 | 08:24 AM
bigcozz's Avatar
I hear a squeek coming from the rear end when going over bumps anyone one else have this problem. I just noticed it about a week ago. Is there something i should look for.
Old Jul 25, 2005 | 08:29 AM
msoemax's Avatar
I too have the same problem. Dealer keeps telling me NPF!
It is worse in colder weather. It has something to do with the suspension in the rear. It may be the rear stabalizer bar, but I am not 100% sure what it is. Rather annoying.
My paperwork stated that the dealer tightened the rear stabalizer bar. It did get better for a while. then it was pretty bad (in 60 degrees and less weather), but now with the 90+ degree days and 65+% humidity it won't squeek. It squeeks only when I hit a bigger bump going over 40 MPH.
Old Jul 25, 2005 | 10:56 AM
NashMax's Avatar
Try lubricating inside the bushings on the RSB. I had the same issue after I changed my RSB and I realized I hadn't used the lube sent with the RSB.
Old Jul 25, 2005 | 11:01 AM
VTmaximaVT's Avatar
i had the same problem, i took it to the dealer and they replaced rear sway bar bushings, and it's fine now.
i was kinda worried that they were gonna say something about my stillen
sway bar, but they said nothing about having aftermarket sway bar...
Old Jul 25, 2005 | 11:28 AM
CanadianMoFo's Avatar
I had this problem on an old 99 Mercury Mistake. The dealer has some unobtanium sway bar grease that was about $80 for a 8oz tube. The service advisor was a friend of mine and let me borrow the tube for an hour to zip home and use it. The stuff did an amazing job and the squeak never came back. I used to have to pull the bushings every couple months to regrease them with a regular style grease.
CM
Old Jul 25, 2005 | 11:48 AM
NismoMax80's Avatar
SuPeRmOd
they probably didn't even know. paying all that, you should demand urethane bushings form Stillen. they have them for the G35 and will give them if you know how to ask.
didn't someone just post about a rear noise? never thought about the RSB
Old Jul 25, 2005 | 11:50 AM
msoemax's Avatar
Oh man that grease is the best!!!!!!!!!!! I remember studying that stuff in class...that and the smoke molecules they secretly put into everything. Once you let those out you are screwed.
Old Jul 25, 2005 | 02:51 PM
I'm not talking about blinker fluid and muffler bearings. There is a specific grease for this application, and it is obscenely overpriced.
CM
Old Jul 25, 2005 | 04:34 PM
msoemax's Avatar
I know what you meant....the name unobtanium was something we engineers used to joke about when the stress got to us in class. It just brought back fond memories...but I can imagine the grease is something that only dealers can find. Perhaps a good auto store...but I knew what you meant....Blinker fluid is a new one to me...hey I need to go grease my mufler so it is quieter ttyl.
Old Jul 25, 2005 | 05:35 PM
VTmaximaVT's Avatar
I don't have the squeeking noise anymore after the dealer replaced the bushings.
the other thread was about the "knocking", "thump" sound from the back.
luckly, I got to experience both noise from the back. well that
squeeking sound is gone. now..i have to get rid of that knocking sound.
going to the dealer tomorrow morning for 3rd time. wish me a luck guys.
Old Jul 25, 2005 | 07:10 PM
Atomic_Ed's Avatar
I don't have the rear squeak but I do have the front end Pirate Ship creaking and groaning noise over bumps and turns at slow speed.
Old Jul 25, 2005 | 07:25 PM
bigcozz's Avatar
Oh i have a 36000 squeaking and creaking pitare ship that should be outsite the mirage in vegas. But i love my ship next time i go in i will have them tighten that up and grease it up nice with their lube and if that dont work i'll tell them exactly what to do with this over priced tubes of goop
Old Jul 25, 2005 | 08:37 PM
hotcory's Avatar
We tried lubricating the door striker plate and that solved our creaking.
Old Jul 25, 2005 | 08:42 PM
jjtricket's Avatar
I will have to try that. Thanks
Old Jul 28, 2005 | 06:46 AM
leroygreen's Avatar
I've got the rear squeak. The techs have admitted defeat. Nobody seems to know how to fix it. It's only on speed bumps though... at slow speeds only.
Old Jul 28, 2005 | 09:37 AM
msoemax's Avatar
It's anything that requires a quick impulse back. for me. Speed bumps are on that list too. My dealer claims those are extreme circumstances. It's been quiet though for a while now since it's nice and warm here...when the fall comes so will the squeeks. good thing I got a lawyer...that's all I can say
Old Aug 1, 2005 | 07:30 PM
bigcozz's Avatar
now it seems i have found the cause my greddy i think its the hangers those cheap rubber one that came with the max hgow do i fix it is it just a matter of spraying some wd40 or what?
Old Aug 2, 2005 | 10:00 AM
ranjittx's Avatar
I wish my car only squeaked when going over bumps!! My car continuously squeaks. It happens when going on a straight strech of road going under 50mph. It is a continuous squeaking, and of course, squeaking also occurs when going over bumps, not to mention a hard knocking noice. I have also noticed that when I close my doors, driver side and passenger side, there is a squeak that seems to be coming from the whole car, not just around the area of the door. Seems real odd to me. Any of you experiencing this?
Old Aug 2, 2005 | 11:58 AM
chrisaust's Avatar
One weird thing to try, but it might be a simple fix... make sure your rear seats are completely latched in place, and maybe lubricate those where they latch in. I had a squeeking noise and finally realized one of the rear seat-backs wasn't latched at all, i slammed it in good and tight and the squeek was gone.
Old Aug 3, 2005 | 01:13 AM
dgrun09's Avatar
suspension related perhaps?
Old Aug 3, 2005 | 07:41 PM
bigcozz's Avatar
if i put my foot on my muffler and push down it squeeks so i think its teh hangers i think someone mentioned this problem with teh greddy brfore i will try to find it.
Old Aug 3, 2005 | 08:26 PM
Boovila's Avatar
Do a search, its been discussed here many times.
Old Aug 3, 2005 | 08:28 PM
04BlackMaxx's Avatar
I feel like most of the noise over bumps originates from my dash area...nothing terrible though.
Old Aug 4, 2005 | 07:50 AM
chrisaust's Avatar
BlackMaxx, I get that too... all that plastic rubbing together... maybe it wouldn't be so bad if I hadn't taken my dash apart a good 15-20 times
Old Oct 19, 2009 | 05:35 PM
trix_05's Avatar
I'm getting this on my 7th gen in the rear suspension. Will be monitoring and taking to the dealer if it persists.
Old Oct 20, 2009 | 04:31 AM
maxed_out_saloon's Avatar
i just heard thos but from the front left strut. i have tein springs so i wonder if its gonna get worse see how that car is dropped
Old Oct 23, 2009 | 07:54 AM
patrick_nobles's Avatar
I have the same problem. Sounds like I'm pushing a 78 Chevy pick-up when I pull into the parking garage. I, like others, have noticed that it seems to be comming from the exhaust pipes... I been under there and can't find specifically where, but it's driving me CRAZY
Old Oct 23, 2009 | 08:11 AM
tunafish51's Avatar
Why don't you take it now? Isnt the car under warranty?
Old Oct 24, 2009 | 05:51 AM
Apollos2's Avatar
Pulled up a 4yr old thread .......LOL but hey it's relavent, so good find. It does have to do with the RSB. I need to get my lubed again, I hate that squeaky sound.
Old Oct 25, 2009 | 08:23 PM
tubells's Avatar
ancient memories!! surprised to see this still happens in the max... i thought nissan fixed it!..
there was a recall for the rsb ...but the recall only applied to areas where there would be more snow (and hence more salt on the roads)....as nissan figured out, only these places would have rust on the rsb....
long story short... my squeaking sounds over bumps (only in winter time)...came to an end once the recall was done!
p.s mine was an '04
Old Oct 25, 2009 | 09:04 PM
Oolatec's Avatar
Progress RSB squeaks as well... just an FYI. Mine is doing it like crazy.
Old Nov 3, 2009 | 04:13 PM
trix_05's Avatar
I brought mine to the dealer last weekend. When riding with the mechanic the squeaks (obviously) didn't show up. However, they still hoisted my car up and lubricated both rear bushings. I thought things were fine but today was a cold day and shortly after starting my trip to work, the squeaking happened again.
I just want this to at least happen consistently so I can bring it back to the dealer and have it make the noise for them.
Anyone else with a 7th gen have this problem?
Old Nov 3, 2009 | 06:22 PM
Oolatec's Avatar
You might want to ask the 7th Gen guys...
kingw323
20
Oct 21, 2015 08:36 AM
Need help
23
Oct 2, 2015 08:56 AM
ivorton23
Sep 26, 2015 09:47 AM
delerium75
Aug 19, 2015 11:08 AM
