Got A Remote Start Installed
For the windows you can simply add channel 4&5 to your lock wires prior to installation. Leave them set at validity and it will control them up&down, no extra parts needed.
I have a CodeAlarm ELITE CA-670..
http://www.powercallsirens.com/ca670.htm
The newest one.. Cost me 700 including install. Glass Break Sensor, and Shock Sensor included.. 1 LCD and 1 Reg. Remote w/LED light... Really Sweet.. I couldnt stand on my last Remote start/alarm i had only one remote... This time i have 2... Mine has about 80 or so settings, and the LCD is awesome... I can set it up to turn on at a certain time from my LCD remote, and other things as well.. Like starting it up during cold temps, and pressing 2 buttons together and it turns on the rear defroster...stuff like that... I have always had remote starts since they came out... Love them...Even the remote, has different tones that you can select.. AWESOME REMOTE START SYSTEM... Took them about 6-8 hours to install.. I had to bring it back so they could fix the doors, so they would unlock as soon as the key was turned off.. There is so much you can do with this system... Also it has the upgradable TELE-LINK, so you can do it from your phone or website access..
This i have heard from a friend who did this(locked his keys inside), but if you have a cell phone, without the added system, and you have someone there at home, or who has your other remote, you can put the cell phone near the antenna, and your friend(spouse) puts the other remote close to the phone it will transmit the signal over the cell and unlock your doors... I havent tried it just yet...
Next step is my PAIN SIRENS, for the interior, and 2 Back-Up Batteries..
Remotes starts are the best thing for your vehicle.. When i get there the temp is right, and my car is ready to go...
Originally Posted by logik05se
I got mine installed at the stealership with a factory nissan remote for 200 bucks...Pays being the manager.
Hell I coulda did ya better than that if ya gave me a good price for a Pathfinder/Armada for my wife.
Originally Posted by -Sin-
Can you turn it on from a half mile away?
The auto lights will work as normal. The procedure that I mentioned mimics the act of opening and closing the drivers door fooling the car into think you have left it. If it is note done, should the remote start time out or if you decide to shut down the engine from the remote the lights will stay on. Another thing that I have done is mentioned here...http://www.carsound.com/UBB/ultimate...=002070#000007, it does work. I used pins 14 and 11. Also note his pin 1 is opposite of what the service manual states so use his picture as reference. All your wiring can be attached at the BCM, triggers (door and trunk), defroster (pin 9 white wire) trunk pop, dome light and I used relays (2 one for each side)to power turn signals for alarm flash (Brighter than parking lights). For window roll down (fronts) you can use a relay if you wish. I did about two weeks of research before doing my own car. Primary web site used were the12volt.com and the link above. I have two sirens. A normal and a battery backup. I put the normal on the ledge underneath the brake booster (you'll need a 12 inch extention) and if you remove the cover over the drivers strut mount you'll notice two bolt holes. I made a mount that screws into that and attached my battery back up siren to it.
Originally Posted by imnotoriousjoe
can adding an aftermarket alarm void my warranty on my bcm since I had it replaced in feb 05 because they said that my alarm/amp shorted the bcm?
Circuit City - PYTHON871XP
I got the Python Alarm + Remote Start installed at Circuit City
http://www.circuitcity.com/rpsm/oid/...etailReview.do
Took them almost 6 hours. Total cost $386.00 installed. I love the 2-way remote. Works like a champ!
Originally Posted by lclrod
Did that just come with the basic remote? Are you able to upgrade to one of the fancy remotes? The price is great, but I'm looking for one of the real nice remotes.
Yea they charged me for the bcm and to find out what the prob was cost about $900
Ouch that's a lot, and a load! Are you going to try to get your money back? How long was the alarm in before the BCM went out? Electronics do die and you may have just had a bad BCM to start with.
Man you seriously sound like you have serious electrical issues. ANd it might be something else that is causing the problem. Get it fully checked out by another dealership, and figure out the problem beofre something really goes wrong.. Good Luck..
No I'm not trying to get my money back I'm just wondering because the dealer put under notes on my receipt "installing alarm or speaker system again will void warranty on new bcm" and I installed the alarm again and now the highbeam lights dont work anymore(no power going to them), but now I go to a different dealer and they didn't know anything about my situation, so I was wondering if the can just tell me I cant add my alarm and void my warranty like that
Well, I got my alarm installed and I love it except for one thing. When I engage the remote start, the parking lights are set to flash while the car is running. I understand this is the default setting. How difficult is it to change this to the alternate setting where the parking lights just stay on?
BTW: The alarm is a Clifford Matrix 3.5.
boone - http://www.directechs.com/guides/man...9564_07-05.pdf
thats your installation manual. its a series of steps, its all in there.
Omar - Excellent reviews all around. Go for it, you wont be disappointed.
ah2002
Mar 9, 2016 01:42 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
