9012 Bulbs....
Old Dec 2, 2005 | 08:46 AM
RVC's Avatar
RVC
9012 Bulbs....
I am looking for a replacement/aftermarket headlight bulb for the Max. I don't have the HID's but I do want something brighter. Anyone know where I can get aftermarket 9012's? I searched and found nothing. Thanks.
Old Dec 2, 2005 | 08:48 AM
Majestic_MAx05's Avatar
From what I've read there is no bulb out there to replace our 9012.
Old Dec 2, 2005 | 09:08 AM
kapesports's Avatar
this is true.. there are places other, lighting company that makes them but somehow i can find stores that carries them ? there is a company called crandlepower out in Canada that makes them... the best bet is to go 9006 with a little riggin it will fit..
Old Dec 2, 2005 | 09:12 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
yea, from what other members have done to install brighter lights is, used the 9006 bulb and cut down one of the tabs on either the bulb or headlight housing to get it to fit inside. the one tab that you cut will not harm the way the bulb is held, it just need to be cut so all the tabs on the 9006 bulb fit inside the hole so then you can twist and lock it in place..
Old Dec 2, 2005 | 09:21 AM
RVC's Avatar
RVC
I thought the 9006 was not as bright as the 9012?
Old Dec 2, 2005 | 10:18 AM
Tek-Niq's Avatar
good question,
I gave you the 9006 bulb idea, but I think that was an HID swap.. I woudn't be sure halogen vs halogen..
Old Dec 2, 2005 | 12:16 PM
TheGame's Avatar
You Don't Wanna Play Me
Try these sites I found the while looking for alternatives, but ended up going with an hid kit.
Scroll all the way to the bottom to see the HB-4 bulb
HB4 Lightbulbs
also try here. Thay have ones in a 9006 platform. I used the 9006 buld in hid and it fit with no modification.
Eurolamps.com
They have 3 types xenon charged Blue/White. direct replacement (no ballast required), Yellow SuperBright ION, and Blue/Gold SuperBright ION
If you e-mail them they'll tell you what set-up will work with your model/year car
Chris
Old Dec 2, 2005 | 02:47 PM
dopestar129's Avatar
The 9006 is not as bright as the 9012. You can buy aftermarket 9006s that are WHITER, but not brighter. If I were you I'd stick with the 9012s. They are quite bright and they are a somewhat new bulb type that lasts longer than traditional halogens. So far I have only found these bulbs on the internet. I believe I found replacements on Ebay. Or you could let the dealer rip you off
Old Dec 2, 2005 | 03:12 PM
RVC's Avatar
RVC
Thanks, I think I am going to forget the headlight thing and just stick with my stock 9012's. I don't want to spend the loot on the HID's.
Old Dec 2, 2005 | 04:00 PM
kapesports's Avatar
then the best thing would be to get a pair of 9006 that has 6000K.. and u all set!!!
Old Dec 2, 2005 | 08:34 PM
CanadianMoFo's Avatar
Try the 9011, high-beam version of the 9012.
charlestek
Jun 15, 2012 02:02 PM
NitrousOxSys
Jan 14, 2009 06:54 AM
y0_nate
Aug 31, 2007 06:40 PM
05MaXiMaMenG
Apr 22, 2005 11:10 PM
