Springs in Front only??? Adverse effects?
Old May 10, 2006 | 05:11 PM
Newblood's Avatar
Wondering if putting Eibach springs to lower the front only on my 06 Max would cause any adverse effects? Any insights are appreciated.
Thanks...
Old May 10, 2006 | 05:18 PM
RA030726's Avatar
I'm nutty for Nissans
More understeer, thats about it. Do you have any other suspension mods? A bigger RSB would off set it slightly.
Old May 10, 2006 | 05:20 PM
kamski's Avatar
.org extraordinaire
When installing Catmans I ripped around with front springs only. Then installed the rears.
Not much difference, only .7 of an inch.
Kamski
Old May 10, 2006 | 05:52 PM
Majestic_MAx05's Avatar
I have only the from eibacs installed and yeah ther is more understeer, but besides that no prob.
Old May 10, 2006 | 05:56 PM
KUBLKMAX's Avatar
I only did the front with my progress but I will have my system finished in about a week and with the added weight I may not want to put the rears in. There is a bit of understeer but it is not dramatic at all.
Old May 10, 2006 | 07:01 PM
jorgep03's Avatar
Silly question guys, What is UNDERSTEER????
Old May 10, 2006 | 07:15 PM
Newblood's Avatar
So I can add a cattman rsb, stillen fsb and eibach front springs and I should be in good shape I presume. Does this sound about right?
Old May 10, 2006 | 07:29 PM
Glude's Avatar
that should be cool, btw u got pm.
Old May 10, 2006 | 07:42 PM
RA030726's Avatar
when your front wheels lose grip and the car plows straight ahead. its easily corrected by hitting the brakes or just letting up off the throttle. cars are dialed in that way from the factory so the average joe does spin out off the road.
Old May 11, 2006 | 06:35 PM
BadBlackMaxSL's Avatar
How hard do you have to be taking corners to feel the understeer with the front only change in the springs? Does it affect normal driving; taking on bumps and dips in the road, and normal speed entrances into turns? Or is it at the extremes limits of the car? Thanks.
Old May 12, 2006 | 02:50 AM
ramberg's Avatar
GrandPa
I have the Eibachs all around. I also have the Stillen anti-sway bar and FSB. Great handling. On the Eibach site it says that all 4 springs should be installed for safety and handling. Why would you not put them in the rear? Its a easy install.
Old May 12, 2006 | 04:50 AM
I'm a sales rep and I have a ton of stuff in my trunk, all of my work stuff which is @ 40lbs, plus my kids team baseball equipment and my golf clubs. This is before any people are sitting in the back seat or a tank of gas which is @ 160 lbs. I don't want to bottom out, so I think its sitting low enough already.
Old May 12, 2006 | 06:11 AM
ramberg's Avatar
GrandPa
I have a nitrous bottle,amp and 12" woofer. I travel alot and at time my trunk is full and I have had no bottoming out problems. The last time I came back from Fl. I had 2 extra ppl in the car. Its only a 1/8" difference.
Old May 12, 2006 | 12:45 PM
po8pimp's Avatar
do you have any problems with more understeer or oversteer????
Old May 12, 2006 | 01:10 PM
Hamy's Avatar
I'm running Eibachs in just the front and it looks great. The ride is a bit harsh, but I have Koni Yellows as well, so that might have something to do with it. If your just after an even drop, thats the easiest way to go.
Old May 13, 2006 | 05:42 PM
Newblood's Avatar
I don't want my rear wheels, assuming I go 19's or 20's to be tucked into the fenderwell. The 18's I have stock sit pretty perfectly in the rear, where as the front is where I need to lower it.
Old May 13, 2006 | 05:49 PM
frankd121's Avatar
You'll only get understeer when you start pushing the car towards its limits.
Old May 14, 2006 | 02:24 AM
ramberg's Avatar
GrandPa
With my set-up. I have no problems at all. I push my ride at times and love the way it handles.
Old May 14, 2006 | 09:44 AM
Right, I was wondering how hard do you have to be driving to experience the understeer. Like taking an average 90 degree turn, how fast is the car going before it loses grip? I don't drive my car too hard, don't want to spill my coffee!!
Old May 14, 2006 | 10:02 AM
ShowMe's Avatar
I have only the Eibachs up front and left the rear factory.....it looks perfect and the ride quality isnt affected at all
Old May 14, 2006 | 01:19 PM
Newblood's Avatar
Can we buy the front eibach springs by themselves? Never actually seen them sold separtely. How much do they run?
Old May 14, 2006 | 02:14 PM
Glude's Avatar
You can't buy the fronts by themself,check your PMs.
Old May 14, 2006 | 11:10 PM
logik05se's Avatar
i have all 4 progress installed, and i normally dont pack my car out...but one day coming home from the gym i had 1 passenger in teh front and 3 in the back...and on 86st in brooklyn there are these little bumps in the road...one BIG one rite after 18th ave which i normally drive around but traffic wouldnt let me...and i bottomed out bad that day. not good.
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
jfl330
Sep 4, 2015 01:44 PM
Justin Kroll
Sep 2, 2015 11:06 AM
