LED DRL's installed
Old May 27, 2006 | 01:51 PM
cwepruk's Avatar
LED DRL's installed
Since I made a thread about this a couple weeks ago, some people wanted to know the results of installed 1156 LED's instead of the stock bulbs that burn out in no time (6 k for me) for the daytime running lights.
Anyways, found some 12 LED whites at the local Canadian Tire.
Since the LED's are forward facing, they don't fill the housing with light, but it's way less yellow and should last much longer.
Here are the pics (sorry about the camera phone quality).
Stock bulb:
LED
Old May 27, 2006 | 01:55 PM
Kevlo911's Avatar
Kevlo for President
Look like glare :wallS
Need better pics. Night pics would help. Or non direct sunlight pics
Old May 27, 2006 | 01:57 PM
cwepruk's Avatar
At night, I would be using the actual headlights.
I'll see if I can get night pics though.
Old May 27, 2006 | 05:15 PM
UnMaTcHeD's Avatar
Not for rookies!!
Yeah, we need better pics.
Old May 27, 2006 | 05:32 PM
cwepruk's Avatar
Those pics are pretty much exactly what they look like. It's been a fairly overcast day.
The second pic is how they look, that isn't a reflection you're seeing. I probably just took the pic in the light beam, itself. Move up or down a bit and it looks like 12 glowing lights.
Old May 27, 2006 | 08:32 PM
cwepruk's Avatar
Here are some twilight pics:
They pretty much look like HID's, except they don't put out much light.
Old May 27, 2006 | 10:26 PM
maX5's Avatar
wow thats amazing... 6th gens look soo much better without the front plate!
Old May 27, 2006 | 11:12 PM
Mystery's Avatar
That looks hot. Only downside is i think people would confuse them for high beams even more then they do now. Otherwise i think it looks great.
Old May 28, 2006 | 10:06 AM
DeusExMaxima's Avatar
I like the look. I wish it were easy to have DRLs here in the states.
Old May 28, 2006 | 10:09 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
If all you guys keep modding your headlights, I will have the only unique set, STOCK XENON!!!
Old May 28, 2006 | 04:35 PM
jsmithsole's Avatar
*moderator*
Looks sweet.
Yeah I looked at the US version and you can see the outline where the plug would go but it's a solid piece. I actually drilled through it to see what was behind and there's what looked like some kind of plate or something, I just gave up at that point...
And for you bulbs you might try the ones I uses on my tails/front blinkers, they will fill the lens with light...
http://autolumination.com/3157_3156.htm
Old May 28, 2006 | 08:03 PM
jingiko's Avatar
hold on these DRLs are on our maximas?
like in the states? so confused
i dont ever remember having DRLs in my headlamps
Old May 29, 2006 | 07:04 AM
cwepruk's Avatar
They are on Canadian cars.
I'm not sure what in that portion of the headlights in US cars.
Old May 29, 2006 | 10:48 AM
kamski's Avatar
.org extraordinaire
Are they brighter then stock?
Old May 29, 2006 | 01:11 PM
cwepruk's Avatar
If lined up directly (as in an oncoming car), yes, but not by much. DRL's aren't very bright to begin with. 1156 bulbs are usually used for back up lights or turn signals. The minute twilight hits, the headlights go on.
Old May 29, 2006 | 04:28 PM
Monotaur's Avatar
Those look VERY nice. Good job!
Old May 30, 2006 | 04:47 AM
Blulytes's Avatar
Very Nice...
Old May 30, 2006 | 06:46 AM
kdejour's Avatar
http://www.cardomain.com/my/ed
Looking good. I wish we had drl's down here.
Old May 30, 2006 | 07:17 AM
Blulytes's Avatar
I'm sure you could add them... just have to drill out the housings, run some wiring... should not be that hard of a modification
Old May 30, 2006 | 09:41 AM
po8pimp's Avatar
or just buy the headlights off of a canadian model.... and run wires no drilling needed = no bulb fitment testing = no cracked lens = no complete waste of money you would have to hook them up to any ignition wire with 12volts uninterupted
Old May 30, 2006 | 12:15 PM
DLy2k1's Avatar
cwepruk, can you please advise what the brand and model number and price of the LED's that you bought from Canadian Tire. Thanks.
EDIT: Is it easy to get at the daytime running lights from the back??
Old May 30, 2006 | 01:18 PM
cwepruk's Avatar
To get to the DRL's is pretty easy. You need a 10 mm socket and that's about it. Twist the washer filler shaft counter clockwise and pull it out, then undo the coolant reservoit (2 10 mm bolts and move it).
On the drivers side, pop off the top of the airbox, remove the lower half and that's all you need.
I bought the Ractive 1156 lights (in the locked section with all the junky accessories). They have blue, red and white in the 1156 size.
Old May 30, 2006 | 01:58 PM
po8pimp's Avatar
I know this is asking a bit but is there a way you could get the part number off the headlight assembly......
Old Jun 16, 2006 | 03:07 PM
cwepruk's Avatar
FYI, I took the bulbs out. Within two weeks one was flickering. At the end of week 2 (ie. today), one was toast and the other was flickering.
I'm assuming the Ractive LED's are pure garbage. Just a heads up to make sure you buy a quality LED.
Old Jun 16, 2006 | 09:25 PM
tubells's Avatar
sidenote: on my third set of DRL's and nissan has finally doen a good job.. this set has lasted me over a year (the potholes are just the same) - another indication (in canada) if u have an 04/05 --- one or both of the DRL's are off! (unless u have had faith in nissan, like me, and changed them several times)
Old Jun 17, 2006 | 10:07 AM
cwepruk's Avatar
I put in some GE long lifers. Hopefully that works good. I might try LED's again, but they are pricey and it's not really worth it if they don't last more than a couple weeks.
Old Jun 17, 2006 | 07:12 PM
n33d45p33d's Avatar
doesn't look bad
Old Jun 18, 2006 | 10:29 AM
jsmithsole's Avatar
*moderator*
Yeah you might have gotten bunk LED's they should last longer than the car!!!
Old Jun 18, 2006 | 11:20 AM
po8pimp's Avatar
I am wondering if they were shorted out because of the power to the leds.... unless there is some sort of resistor built in I think 12volts would short them..... leds typically can take 3-5volts.... 12 is alot and will deffinitly shorten life span....
AaronL
Nov 15, 2020 11:52 AM
doctorpullit
Jul 20, 2019 09:31 PM
MaxLife17
Jun 27, 2019 01:37 PM
minsbang
Sep 11, 2015 08:48 PM
mpbclutch33
Sep 8, 2015 06:21 PM
