Chernmax 6th Gen Dyno Numbers
Old 08-30-2006, 01:21 PM
  #121
3.5 Lover's Avatar
Chern; do you have a manual or auto? Your sound clip sounds like an auto. I wonder if the auto trans in our Max can handle a supercharger or turbo if one becomes available.
3.5 Lover is offline
Old 08-30-2006, 04:53 PM
  #122
dot dot dot ...
NmexMAX's Avatar
He's auto. .
NmexMAX is offline
Old 08-31-2006, 05:12 AM
  #123
Puppetmaster's Avatar
If the 5AT in the G and Z can handle a good amount of FI, I'm sure you'll have no problems. You could always get one of those valve body upgrades when the time comes.
Puppetmaster is offline
Old 09-14-2006, 09:08 AM
  #124
MD 06 MAX's Avatar
Chern, nice numbers, i got the headers install on my 06 max a week a go but the SES light came on did this happen to you? is so how did you make it go away?
MD 06 MAX is offline
Old 09-14-2006, 10:05 AM
  #125
Nations 1st 6th Gen Turbo
chernmax's Avatar
Did you rehook up all your 02 sensors? If yes, did you have the car Dyno Tuned? In all I wouldn't be overly concerned, just go to any Autozone or Advanced Auto and let them hook up (Free Service) an OBD-II and write down the ECU fault codes. Have them erase the ECU codes and your SES light will go out. If the SES light comes back on after a period of time, go back to the Auto store and get the codes read again in case they changed.
Last, I would check to see if they properly wired the 02 sensors or make sure they didn't melt (possible if installed too close to the the Y-Pipe! Happened to another member).
Good luck...
chernmax is offline
Old 09-14-2006, 02:29 PM
  #126
AltiAzul's Avatar
Since you are an 06, and if the light is P1273/P1284 then you will have to live with it. You have A/F sensors as your primary O2 sensors. Chernmax is an 04 which means we doesn't have A/F sensors, thus no SES light. If it is any rear o2 related code, check the wiring.
Edit: The car will run fine, the A/F sensors do not like the voltage to vary too much from what equates to a 14.7:1 A/F mixture. Bank 1 is too lean and bank 2 too rich for the ECU's liking.
AltiAzul is offline
Old 09-14-2006, 02:34 PM
  #127
Glude's Avatar
I dont think theres any change from 04-06 with the sensors.
Glude is offline
Old 09-14-2006, 02:36 PM
  #128
AltiAzul's Avatar
On the Altima's the 04's still used a 3 wire 02 sensor for the primary sensor (before the cat) and the 05+ use a five wire wideband A/F sensor. It is probably the same on the Max.
AltiAzul is offline
Old 09-14-2006, 04:06 PM
  #129
chad9350's Avatar
Confirmed
...found that out about the 5 wire wideband when installing headers.
chad9350 is offline
Old 09-14-2006, 04:39 PM
  #130
Glude's Avatar
hmm, that sucks. Glad I have an 04 so when the time comes I wont get any codes.
Glude is offline
Old 09-14-2006, 04:57 PM
  #131
aka The Doom Ship
AllBlackMax's Avatar
Bring on the dyno.
AllBlackMax is offline
Old 10-23-2006, 04:33 AM
  #132
.org extraordinaire
kamski's Avatar
Originally Posted by chernmax
OK understand, just an FYI for all:
Part#:NS3018
Application: Nissan Altima and Se-R (will fit manual and automatic)
Link: http://www.hotshot.com/main_new.html
How often do thease give you the CEL light and how often to do you have to reset it?
Kamski
kamski is offline
Old 10-23-2006, 02:08 PM
  #133
chad9350's Avatar
Relocate sensor...
Relocate sensor, all is well...
chad9350 is offline
Old 10-23-2006, 07:34 PM
  #134
big dave's Avatar
Real impressive numbers. Definitely should get you into the 13s. Where in Beltsville is this shop located? I'm only 10 minutes away from Beltsville
big dave is offline
Max139617
09-20-2015 07:09 PM
Vequity
09-10-2015 05:26 AM
Maxboy23
09-04-2015 06:04 PM
mikebla
09-03-2015 05:37 PM
Quick Reply: Chernmax 6th Gen Dyno Numbers
