Shimmy Fixed & Bluetooth & Grinding Acceleration Noise
Old Aug 6, 2006 | 03:49 PM
Defiant_Max04's Avatar
Whoever else had that Shimmy from their 04-06 Max's, take it right into Nissan. They will fix the problem for you. I can't believe they actually fixed it. Also bring your Maxima's in for a few recalls. When I brought it in, they fixed the sunroof, and two recalls regarding the power seats, and one other recall that stopped the grinding nose when accelerating.
Anyone know where to get aftermarket Bluetooth for the Maxima? My loaded SE never came with it (I'm pissed).
Thanks.
Old Aug 6, 2006 | 05:02 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Thanks.
I didn't get the shimmy option with mine (call me freakin lucky), recommend a blue tooth earpiece, a hell of a lot cheaper than trying to convert an 04 Max...
Old Aug 6, 2006 | 05:37 PM
kamski's Avatar
.org extraordinaire
Nokia Bluetooth is whicked,
http://www.nokia.ca/english/pics/acc.../hs24w_lrg.jpg
wonderful piece of technology.
Kamski
Old Aug 6, 2006 | 08:00 PM
Majestic303's Avatar
Thanks.
I wish i had that luck! brought my 04 SE to THREE dealerships who can't fix the shimmy problem on mine!.. congrats!! hehehe
Old Aug 6, 2006 | 10:19 PM
Snobgoblin's Avatar
Did they fix it for free?? My Warranty is up and I want to get that Grinding Noise fixed. Is it the heat covers or something?
Old Aug 7, 2006 | 04:48 AM
04BlackMaxx's Avatar
The grinding noise isnt a recall right? Id take it in if it was, otherwise im out of warrenty and would just leave it.
Old Aug 7, 2006 | 05:32 AM
BadBlackMaxSL's Avatar
Are you going to share with the group on what they did to fix your issues or are they going to remain a secret?
Old Aug 7, 2006 | 08:53 AM
Well, I have no idea what they did to fix the grinding acceleration noise. However, they changed the front brake pads and resurfaced the rotors. They charged me a little bit (unfortunately), but it was worth it. Went 80 on the highway and hit the brakes, and no shake. But there are recalls with the seats.
Just call your Nissan dealer and ask them about the recalls for the Maxima and if you want bring it in and see if they can fix that annoying shimmy. I couldn't even do 40 and hit the brakes without the shimmy.
Old Aug 7, 2006 | 09:18 AM
Lovemycar's Avatar
The shimmy doesn't come when you apply the brakes the wheel shakes around 45-60 also beware because mine was fixed to and it came back
and this is not just an 04 issue 04-06 has shimmy to.my 04 shimmys
very little this is after they replaced two tiers balance and rotors
i will be doing the TSB on mine soon
Old Aug 7, 2006 | 09:26 AM
Lovemycar's Avatar
Not sure what you mean but it sound like your rotors were warped that's why the wheel was shaking when you applied the brakes the shimmy that i no
is when the steering wheel shakes around 45-60, and it's not just and 04
issue - 04-06 has the same problem
beware it's none to come back
pears
Sep 18, 2015 05:25 AM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
jcvgn
Sep 10, 2015 08:03 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
