taillight replacement
Old Dec 29, 2006 | 06:04 AM
lobewiper's Avatar
-Does anyone know how to replace taillight bulbs on an 04? There are a couple of retainers that hold the corner cargo net that appear needful of removal to take off the interior panel covering--do these have to be taken off first? Any help will be much appreciated. Thanks...
Old Dec 29, 2006 | 06:08 AM
maxchef's Avatar
I can tell you about the cargo net clips but not the rest. Pull out the center of the retainer using a flat head of somthing to get underneath it, that should just pop out and then so should the other part as well after removing the center. Make sure when you put it all back together that you notice that the center is keyed and can only go in one way.
Hope this helps!!!!!!
Chef
Old Dec 29, 2006 | 06:40 AM
lobewiper's Avatar
Thanks, Chef.
Got the cargo net retainers out per your instructions. Now what to do? I see a couple of brass-colored bolts with nuts. I wonder if I remove them whether the whole light assembly will come out of the car... Nissan sure didn't make this easy to do.
Old Dec 29, 2006 | 07:19 AM
!PrjctMax!'s Avatar
There are 3 screws holding the tail-light in...I believe 2 on top and one on bottom or vice versa...once you take those out make sure to carefully wiggle the light out because if you do it quick then it'll slip out and scratch your bumper-I know from experience
good luck
dan
Old Dec 29, 2006 | 08:00 AM
jsmithsole's Avatar
*moderator*
Read the sticky I put together, it's all there:
http://forums.maxima.org/showthread.php?t=455704
(post # 2, 2nd pic)
Old Dec 29, 2006 | 09:54 AM
lobewiper's Avatar
Thanks, guys. Was able to R & R light assembly and replace bad bulb. The upper cargo retainer wouldn't stay in when replaced, so will need a new one of those, but otherwise, saved sum bux!
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
