Won't start!!
Old Jan 12, 2007 | 07:33 PM
03maxsiny's Avatar
Won't start!!
Hey all, i have an 05 maxima SL with an At, and it wont start. Battery is fine, i tried jumping it, but when i turn the key, all i hear is the click from the solenoid and no cranking at all... what can be wrong? thanks in advance!
Old Jan 12, 2007 | 08:01 PM
!PrjctMax!'s Avatar
You need to charge it for a longer period of time. Highly doubt anything major is wrong with the car. If it has been sitting for quite some time then the battery just drained by itself; it happens at the stealership that I work at, and when it does happen we just put a 45 minute charge on it and it's good as new!
dan
Old Jan 12, 2007 | 08:22 PM
03maxsiny's Avatar
dan
even if the car doesnt crank? this makes no sense.
Old Jan 12, 2007 | 08:29 PM
03maxsiny's Avatar
ok, lets say this is the case, i do have another question. Do you know what could have caused this problem? i recently installed a PAC aux in adapter and i tapped a line driver into the power for the 12v next to the shifter. do you think that this could have effected it? i dont see how the battery just died, as i started it earlier in the day with no problem.
Old Jan 12, 2007 | 08:51 PM
!PrjctMax!'s Avatar
If it doesn't crank at all then it's purely dead! And if you have the PAC thing constantly on, then that slowly drained your battery.
Old Jan 12, 2007 | 08:54 PM
03maxsiny's Avatar
could it be something other than the battery being dead? i mean, it doesnt seem like the batt is dead... all of the lghts are on in the car, and when i try to start they dont really dim... all i hear is the click from the solenoid, and no attempt to crank.
Old Jan 12, 2007 | 09:18 PM
Killah Kane's Avatar
If you are jump starting it and all you hear is a click, chances are that your cables are not thick enough. Try using a thicker more heavy duty guage cable, same thing happened to me. I was trying to jump my car with thin cables, As soon as I used a thicker guage cable it started right up.
Old Jan 12, 2007 | 10:15 PM
SmokeNismo's Avatar
Same thing happened with my former car, a 98 corolla, the battery was fine. It turned out that the starter needed to be changed.
Old Jan 13, 2007 | 09:50 PM
03maxsiny's Avatar
jus got back from the dealer, turns out the starter was seized. Changed that bad boy nd im all good
Old Jan 15, 2007 | 08:30 AM
Willow's Avatar
I had that on my 2000 SE once. I took it into a dealer and they found it was a relay on the ignition side.
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
