Tire change problem.. help please.
Old Feb 13, 2007 | 08:41 AM
Nameth's Avatar
Ok, so I have a 2004 Maxima 3.5 SE, and I get a flat rear-passenger tire. Not really life or death, so I decide to change it myself. I *think* I have 245/s18's, aluminum 5 spoke rims. There are no lug nut locks that need(ed) to be unlocked, as I managed to get all 5 lugs off no problem.
Ok so here is where it gets bad.. with all 5 lugs off, the tire wont move an inch. It is not loose, nor does it feel like it intends to become loose I have no idea why it is this way. I removed the spare fromthe trunk, same wheel/rim/rubber, and had a look to see if somehow its locking from the rear, and it doesnt look like anything would be doing it.
So what could the problem be? I dont think there could be a center bolt/nut holding it on.. because I cant see anything that would do that on the spare.. and I cant get the little 'nissan' lid off the centre of the rim to see inside either.. so Im at a loss..
Does anyone know what Im doing wrong? Ive kicked the tire, placed weight back on it to see if it would pop off the studs, pulled it hard, and nothing will budge it.
Thanks for any help..
Nameth
Old Feb 13, 2007 | 09:08 AM
NVRSATISFYD's Avatar
odd, mine just popped right off...try beatin on it some more...maybe a huge rubber mallet? A little violence sometimes is key!
Old Feb 13, 2007 | 09:29 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Old Feb 13, 2007 | 09:55 AM
Nameth's Avatar
Youd think though, that once I let off the jack enough that the tire was resting on the ground would be sufficient enough force to get it to pop off.. but it didnt.. I cant get to violent with it due to it being on a lame looking jack
So that center "nissan" logo cap in the middle of the rim means nothing? It seems like a pain the the ***...
I guess I shall just have to abuse the tire until it surrenders..
I will also try to remove another tire, just to see if it comes off easily or not.
Rediculous
On a secondary note, my wife backed into a pole and cracked the rear bumper.. not good.. does anyone knows where I can find a decent place to buy parts? Im new to the forums, so just thought Id ask. Im also in Canada, Calgary to be exact, so anyone with any local would be awesome
Nameth
Old Feb 13, 2007 | 10:09 AM
MacGarnicle's Avatar
how cold is it where you are? -20 or colder? could be that the rim is frozen to the rim.. is your car in the garage?
Old Feb 13, 2007 | 10:27 AM
SilverMax_04's Avatar
With the 5 lug-nuts off, the wheel should be loose. The idea about frozen to the hub is probably likely. You need more force on the side of tire in one place to help break the wheel loose. Understand that you don't have a good jack. May need to buy a better jack and a good rubber mallet to hit the tire very hard.
Old Feb 13, 2007 | 10:29 AM
CoolMax's Avatar
is invisible
http://forums.maxima.org/showthread.php?t=510737
Old Feb 13, 2007 | 01:35 PM
Nameth's Avatar
Yes.. its cold as hell here right now.. Id say -20 sounds about right.. the car is in the gargage.. so maybe that will help it a bit.. but its not heated.. I have a space heater Ill use to throw some directed heat at the rim..
I did think of the cold being a factor, but damn.. 4000 lbs of car on the rim and it wouldnt give.. that to me is whack..
Thanks for the help.. Ill give it a shot
Old Feb 13, 2007 | 02:02 PM
There are 4 wheels and the rear ones get less weight than the front. A shock also helps, but would not suggest dropping the car off of the jack. Hope the heat works for you. Good luck.
Old Feb 13, 2007 | 03:02 PM
CoolMax's Avatar
is invisible
i need this post to ask questions...almost there
Old Feb 13, 2007 | 03:31 PM
xoomer.com's Avatar
I Donate! Why Don't You?
What da heck??????
Old Feb 14, 2007 | 06:28 AM
CoolMax's Avatar
is invisible
Originally Posted by xoomer.com
What da heck??????
i need 15 posts to ask my question...almost there...
Old Feb 22, 2007 | 02:19 PM
pnoy77's Avatar
i had this problem before... i called a tow truck guy and he just kicked it... it came off...
MR2 T'd
Jul 9, 2021 05:06 AM
Mar 12, 2020 12:06 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
ag90fox
Sep 9, 2015 12:22 PM
jfl330
Sep 4, 2015 01:44 PM
