?'s on removing front lft fende...
Old 03-09-2007, 04:53 PM
"Ok,Whats next?!?!"
Fastmax05's Avatar
Well...
long story short, i was in a hit adn run and i was not able to catch the person...
My front left fender needs to be replaced... I have puchased a new fender and its painted...just need to install it... anyone have any idea how easy it is to remove it... ??? or install directions..
Fastmax05 is offline
Old 03-09-2007, 05:20 PM
!PrjctMax!'s Avatar
There should be a few screws on the top and then some under the splash guards and I would guess that you'd be set.
!PrjctMax! is offline
Old 03-09-2007, 05:23 PM
"Ok,Whats next?!?!"
Fastmax05's Avatar
really? that easy...?? sounds lke a half hour job ... anyone else have any imput?
Old 03-09-2007, 05:27 PM
!PrjctMax!'s Avatar
Well, it's not a Corvette fender (it's about 1/3 of the car length!) so i'd assume it's pretty easy. I want to say that there are 3 screws on top and then there might be 2 that also hold the bumper on, and then more UNDER the splash guard.
Old 03-10-2007, 10:15 AM
"Ok,Whats next?!?!"
Fastmax05's Avatar
anyone else??????????
Old 03-10-2007, 02:32 PM
!PrjctMax!'s Avatar
why don't you just pop the hood and check it out for yourself?
Old 03-10-2007, 02:36 PM
"Ok,Whats next?!?!"
Fastmax05's Avatar
I have and i saw three bolts.. but not sure on the ones that r hooked up to the bumper... do i need to remove the bumpoer to get to them... im just looking for an answer from someone who has done it...
Old 03-10-2007, 02:47 PM
moparkidd's Avatar
well, just tear into it id say, look around alot in and out and under and around, take out some bolts, when it gets loose you should be able to tell which bolts need to come and and not, just trial and error it, seems like not many have done this.
moparkidd is offline
Old 03-10-2007, 03:26 PM
Favs's Avatar
Hey question!!! why dont you check out the fender you bought and see what holes belong to where.... I do know that to remove the fender you for sure have to remove the Head lights... to get to one screw... In order to get the lights out... you have to remove the bumper... So there fore you would have to pop your hood and manage all that........So long thing short... Remove Bumper , all 5 screws to remove light, then remove fender all three or so scewes on top and then one that is the held by light and then a couple by the spalsh guard...... Hope that helps... I hope its all correct... It was a while since i took mine off..
Favs is offline
Old 03-11-2007, 08:01 AM
KC's FINEST
KCMAXX's Avatar
You can remove a fender without dropping the bumper or the lights... Just a handfull of screws and clips.
KCMAXX is offline
Old 03-11-2007, 12:34 PM
"Ok,Whats next?!?!"
Fastmax05's Avatar
PERFECT... This is exactly the response i was looking for...someone who has done it.. THANKS KC max... how long did it take u to find all of them... Was it preety easy??? thanks again
Old 03-11-2007, 12:35 PM
"Ok,Whats next?!?!"
Fastmax05's Avatar
Im not looking to get into something and then findout that i F'd up... Thanks for trying to help...
Old 03-11-2007, 12:55 PM
moparkidd's Avatar
lmao yeah im a retard.
Old 03-11-2007, 04:27 PM
KC's FINEST
KCMAXX's Avatar
There really isnt anything to it. Once you remove a few of the top bolts, wiggle the fender. You'll find the rest. I pulled the wheel liner out before I started on mine. Good Luck...
KCMAXX is offline
Old 03-11-2007, 08:08 PM
madmik's Avatar
Tks a million Kcmaxx. My neighbor backed into my right fender last fall. Estimates ranged from $650-$950. She gave me $1K. All shops said (and service manual too) bumper and headlight had to come off. Was hesitant but after seeing your picture/answer, its a go.
Fatsmax05, where did you get your fender? On Ebay, Unique Customs has them painted for $249 ($429 for OEM part).
madmik is offline
Old 03-11-2007, 08:40 PM
AlpineGt66's Avatar
anyone know if a fender can be repaired if its bent?
AlpineGt66 is offline
Old 03-12-2007, 12:51 PM
KC's FINEST
KCMAXX's Avatar
"Bent?" More than likely if it's dented it can be. Unless it has a definite crease. Post pics of what you mean by bent...
KCMAXX is offline
Old 03-12-2007, 01:05 PM
Blulytes's Avatar
Get this man a beer! I could not have said it better myself.
Probably the easiest first step in this process is to take off that wheel... This will give you more access, however there is a bolt to the side of the headlight which I know is difficult to get to without the bumper coming off...
but don't get frustrated when you think you'll get this done in 30 mins.
Blulytes is offline
Old 03-12-2007, 01:45 PM
"Ok,Whats next?!?!"
Fastmax05's Avatar
I found a place here in so cal that will sell me a brand new fender not oem but brand new aftermarket for 50 bucks if i pick it up.. or 110 to ship it.. they are like 25 mins from me so i said F it right????
Then i was goign to take it to a local body shop ...they said 250 to paint it...
Whats the site that u have for 250 painted????
have u purchased from them and had something painted... did it come out PEREFECT????
Old 03-12-2007, 01:55 PM
"Ok,Whats next?!?!"
Fastmax05's Avatar
I googled them and found the site ... numbers...etc.. they said that they can have it shipped for 299 to my door... ships in 5 days... be to me in 8 buss days... from today... Not tooo bad ... thanks for help...
Old 03-12-2007, 08:17 PM
AlpineGt66's Avatar
Old 03-12-2007, 11:16 PM
Favs's Avatar
So we got a Merks... sweet... That dent can defenitely be taken off it has no crease at all ... It pretty much has to be popped out hopefully tho it doesnt crack the paint... that probably the biggest problem.. Merks paint is a bit more pricy.. but if thats cool then the dent should come out after a lil work on it..
Favs is offline
Old 03-13-2007, 08:32 AM
KC's FINEST
KCMAXX's Avatar
I would try removing the wheel liner and see if you can pop it out any. If not call a dent removal shop. Most of them have suction tools to do it the right way.
KCMAXX is offline
Old 03-13-2007, 09:10 AM
"Ok,Whats next?!?!"
Fastmax05's Avatar
But like someone said earlier... u run a good chance of cracking the paint... so dont be disapointed.
Old 03-13-2007, 11:52 AM
I Donate! Why Don't You?
xoomer.com's Avatar
I've seen worse dents that were "pulled" "sucked" "poped" what have you.
Very do-able.
xoomer.com is offline
Old 03-13-2007, 01:22 PM
AlpineGt66's Avatar
do you guys see that it has 2 bends and a dent? look at the bottom of the fender, near the lower trim.
Old 03-14-2007, 11:22 AM
"Ok,Whats next?!?!"
Fastmax05's Avatar
Just make a all and have an estimate ...they are free
Old 03-14-2007, 11:41 AM
Favs's Avatar
Yeah i see that... they should be able to popped it out the paint is for sure cracked ... You might be better off getting a new fender and repainting it then that area will be vonurable to bending easier.. thats just me tho... go get an astimate and see which is better off for you..
Favs is offline
Old 03-14-2007, 07:01 PM
AlpineGt66's Avatar
i am just going to take it off take it to a body shop, and see what they tell me. Anyone know if when painting the front end, a body shop takes the panels off to paint them or not? Since I was thinking of doing a conversion, and need the bumper repainted, now this fender, and a little bit of the hood to where I will cut it. So my question being does anyone know if a body shop paints panels with them on the car or not and, if they can match the paint from the fenders and hood to the bumper, rather than me bringing them the car.
The Frye
09-02-2021 11:03 AM
AcuraLegend
10-17-2016 08:47 PM
AcuraLegend
09-22-2015 04:22 PM
dvcamp
09-18-2015 10:17 AM
Maxima30
09-07-2015 06:13 PM
Quick Reply: ?'s on removing front lft fende...
