Service light on
Old Jun 14, 2007 | 06:11 PM
Lovemycar's Avatar
Service light on
Guys i changed my air filter and i forgot to plug the MAF in and
now SES light is on how can i reset that
Old Jun 14, 2007 | 06:25 PM
2LEET4U's Avatar
it will go away in a week.... or unplug your battery and leave the car door open in order for the 15 minutes. then connect the battery.
Old Jun 14, 2007 | 07:00 PM
Lovemycar's Avatar
will i need to reprogram my run roof if i remove the batt and if so is it hard to do
Old Jun 14, 2007 | 07:04 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
run roof??? is that sun roof???
Just disconnect your battery...
Make sure its pushed to the side not touching any metal...
Go in hte car and turn the car to the "ON" position and hold it there for 15 seconds... Like u would be trying to turn the car on...
Once you have done this for around 20 seconds or so... get out then connect the Pos battery cable...
This should reset it
Old Jun 14, 2007 | 07:08 PM
Lovemycar's Avatar
Again will i need to reset my SUN ROOF
Old Jun 14, 2007 | 07:13 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
i have never heard of reseting a sun roof... so i have no idea... what makes you think u need to reset it????
Just make sure its closed... then do what i said... it all will work fine...
Old Jun 14, 2007 | 08:54 PM
4MySwee's Avatar
Yes, you will.
Fastmax05,
If you fiddle with the battery at all, as far as connecting and disconnecting, your sunroof switch will only operate at less-than-half opening.
Your manual tells you how to. I can't remember how, but I do know it was something really simple. Such as 'open all the way, close and open again'....some simple process.
Swee
Old Jun 14, 2007 | 09:02 PM
MaxFan's Avatar
Shouldn't the rule is to disconnect the Negative cable 1st. That way it (and your tool) can touch anything (all ground except the Positive terminal) without blowing up your car.
Old Jun 15, 2007 | 12:07 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
4myswee: hmmm never heard of that... and i ahve owned cars w/ sunroofs...
i have the dual roof thing in my se... so i dont have to worry about this
Old Jun 15, 2007 | 04:05 AM
ramberg's Avatar
GrandPa
Here's the ECU reset info, the timing of each step is critical, some members have reported they had to repeat 4 times or more before they got it right. Also at he bottom is a link to a another reset, but it appears to be the same steps, save for future use.
------ECU reset------
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON.
A stop watch or an analog clock with a second’s needle will be useful.
Operations Procedures
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
http://maxima.theowensfamily.com/ecu.asp
Old Jun 15, 2007 | 04:07 AM
ramberg's Avatar
GrandPa
Press the bottom of the black button that the controls the sun roof for 20 seconds. It should work than. Also check your manual its in there.
Old Jun 15, 2007 | 05:10 AM
Lovemycar's Avatar
i tried the battary thing that didn't work how long does it need to be disconnected i tried it for maybe 10-20 sec should i have done it longer and do i need to disconnect the POS or NEG or both
Old Jun 15, 2007 | 12:31 PM
Lovemycar's Avatar
Guys can some one help me with this i can't get this to work i know nothings
wrong with my car
Old Jun 15, 2007 | 02:02 PM
ramberg's Avatar
GrandPa
wrong with my car
Did you try what I posted in reply 10? It took me two times to get it done.
Old Jun 15, 2007 | 03:23 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
Thats a great post ramberg nice detail
Old Jun 15, 2007 | 06:18 PM
Lovemycar's Avatar
Thanks guys i did try both things but they didn't work i couldn't get the ses light to blink and disconnecting the batt no go either so i just went to
auto zone and had then reset it for me with there reader thingy and it's all good now just need to remember to plug that MAF in after changing air filter
thanks again guys for your help
fastmax5 nice mods
Old Jun 16, 2007 | 03:29 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
fastmax5 nice mods
sorry we couldnt help more.. what did they charge you??
As for my mods, thanks! i have a few things on the way too... Stillen lip in a few weeks... SACF2 and the Ypipe from cattman should have around 300hp to the fly... not tooo shabby
Old Jun 16, 2007 | 03:30 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
P.S. post some pics of your ride man ... start a new thread though...
Old Jun 16, 2007 | 05:05 AM
Lovemycar's Avatar
At Autozone it's free and i'll post some pic's soon not much done to it yet but
20% tint
billet grill
07 spoiler
crome door handles
and i keep that **** clean
More to come
Old Jun 16, 2007 | 06:23 AM
Elimackman's Avatar
Driving to autozone is a lot easier than the scientific method of reprogramming that Nissan came up with... I had the same problem not that long ago
fastcarny
Oct 6, 2015 10:42 AM
minsbang
Sep 11, 2015 08:48 PM
Maxima30
Sep 7, 2015 06:13 PM
jfl330
Sep 4, 2015 01:44 PM
