OMG ENDLINKS
Old Oct 20, 2008 | 12:28 PM
  #41
Fastmax05's Avatar
"Ok,Whats next?!?!"
Use the search button, highjacking is not nice ...
Old Oct 20, 2008 | 02:41 PM
  #42
chernmax's Avatar
Nations 1st 6th Gen Turbo
Originally Posted by pavetim
If I were to get the SE-R bar would I just get the same year altima as my max? I have the 2005 maxima and looking to upgrade i have alot of the banging around the front that you guys seem to have also.
Actually no, but you're in luck, the Altima Front Anti-sway bar (24mm) is for the 2005 Nissan Altima SE-R anyway.
Old Oct 20, 2008 | 08:53 PM
  #43
Staggered357's Avatar
THIS IS MY QUESTION... what exactly do the endlinks do? are they similar to a camber kits? i am lowering my 08 MAX SE, with Eibach springs..I put a camber kit on the front just in case for when i get an alignment...will the endlinks perform a similar function or are they two different things altogether...
Old Oct 21, 2008 | 01:58 PM
  #44
chernmax's Avatar
Upgraded Endlinks should be used with any upgraded Sway Bar as your factory Endlinks may not be up to the task of handling increased stiffness, but of course, installing an entire matched set of Sway Bars and Endlinks is recommended for the best performance and reliability!
Old Oct 21, 2008 | 02:00 PM
  #45
Oolatec's Avatar
Stiffer ride... better cornering... etc...
Old Oct 23, 2008 | 04:16 AM
  #46
ok..got you..so its not a necessity but an improvement... which means i should ride lowered for a bit, get used to that then do the sway bars, endlinks and strut bars to really be able to experience the difference.... thanks
Old Oct 23, 2008 | 04:18 AM
  #47
thanks...point taken..lol
kingw323
20
Oct 21, 2015 08:36 AM
Bonka
Sep 14, 2015 11:18 PM
ChrisCheezer
20
Oct 22, 2002 09:22 PM
sunnyb32
Jan 5, 2002 05:07 PM
Turbo95Max
Dec 10, 2001 05:47 AM
