tranny cooler? oil cooler?
Originally Posted by QwikKota
What irks me is TS doesn't even post dyno sheets or list average or peak hp gains from customers cars.
SAFC doesn't have anything to do with timing which is where most horsepower is made from available bolt ons. Pretty good #'s for not touching the advance.
http://forums.maxima.org/showthread.php?t=325775
Originally Posted by Look-at-my-MAX
oh noess ive been exposed! lol
I'd rather have the raw data feed that proves that they actually changed some parameters for the 'better' vs a poorly done dyno.
But it can:
It be nice to have runfiles.
But it can:
I did not know the ECU would react to the larger injectors that way but it seems risky to tune it with that method. Pulling fuel and adding timing etc. As long as the A/F looks good then so be it. I don't think Phillip is using that approach however.
I'm not talking about the actual programming data, I'm talking about actual data files that state, yes, this parameter which will affect performance has changed.
Kinda like this this: http://forums.maxima.org/showpost.ph...79&postcount=6
That's not exactly how it works, but you're catching on.
I never said he was, I did state, however, that the SAFCII CAN be used as such a tool.
ECU wont react to larger injectors when WOT, only run richer. Otherwise, no matter what size the injector (within reason), @ part throttle etc, the ECU will keep close to stoich, but the STFT & LTFT's will be larger (greater correction % value)
DAMN! whats this stuff have to do with my tranny cooler lol. but anyway i will be installing a lil something in the spring and will retune with wideband. after that ill get a dyno to see what my numbers are and post run files etc.
Don't some of the older Max's have them factory?
That full tunable version of Osiris sounds good. But if I can get a UTEC for cheaper than Osiris I'm going that way.
5AT has a tranny cooler build into the radiator. Connections are on driver side.
Under the oil filter is another cooler hooked up to the rad. The power steering is also cooled. Connections on the passenger side of the rad.
tarun900
19
Dec 20, 2021 06:57 PM
05RLS2
Apr 14, 2016 11:49 AM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
I am hopefully on that route...
