Define "shimmy"
Define "shimmy"
I haven't had my 04 very long, so I'm just getting used to it.
I'm in fear of getting the dreaded shimmy. Any slight movement in the wheel drives me nuts.
I thought I got a some shimmy yesterday.....wheel seemed like it was moving quite a bit side to side.....but only on one part of the highway for 15 or so seconds.
I did remove the plastic piece last night......noticed no difference.....although I couldn't replicate the shimmy cause I'm not positive where it occurred.
I spoke with an ex Nissan tech I know from racing......said the cure for true shimmy is tightening the steering rack....I think I may have seen a TSB for it.
But......back to my main question.....I get a little bit of vibration in the wheel......not a ton.....but enough to notice. Its intermittent, mainly happens on the highway at higher speeds. Is that "shimmy? Or is "shimmy" the wheel moving back and forth pretty crazy? Do I just have some vibrations in my wheel from normal stuff like wheel balance, etc?
I did just get new F1s, and an alignment that is not 100% perfect. I was thinking of getting the Road Force balance and taking the car back to perfect my alignment.
With these types of tires/wheels.......will the slight vibration just be something that I'll have to live with?
There are many threads on this if you search. Vibration and shimmy are 2 different things. Back and forth is a shimmy, vibration is ...well a vibration. Check your tires and balancing first and then your rotors for any defects.
Yep I've read many threads on this. I just wanted to make sure I am chasing down vibrations and not shimmy.....I don't believe I have shimmy but wanted to confirm.
I've only known warped brake rotors to cause vibration while braking. Are you telling me that they can cause it while just driving down the highway?
Back to the plastic piece for a second......does one only need to cut the lip, or remove it together if they have shimmy?
Ah yes.
Alright, first off, all you need to do to fix the shimmy that is generated from the plastic piece is shave the lip. If you took it off (as did I), no loss. Most cars don't have plastic under them.
Two. You would know if you had a shimmy. It wouldn't need "replicated" it would be all the time. Number one reason you get the shimmy - tire balance. You need to have your car Hunter Force balanced with a computer balance. Our cars are extremely sensitive. Case in point - I had my car balanced three separate times by three separate shops when I got new tires on it. The car shimmy'd like mad. I got it Hunter Force balanced and BAM no more shimmy.
You could also have uneven tire wear due to not rotating and misalignment.
But trust me, if you are questioning whether you have a shimmy or not, you don't have it. You would know if you had it.
Joshua
Joshua
Update:
I had my alignment rechecked - all within spec.
Went back to Goodyear and asked them about the Road Force balance - $27 a tire. They said to try the free lifetime "regular" balance first before paying for the Road Force. (Ironically, I called the stealership and its only $44.99 for all four tires)
They balanced the tires and the vibration is as good as gone. BUT....the car still pulls to the left. My alignment is within spec, but they said that the camber and caster are .4 off to the left.....COULD cause the slight drift....but should not as those numbers are supposed to be acceptable. The camber and caster are not adjustable from the factory, it requires a kit plus a new alignment.
They did say that the drift COULD be a bad tire. They wanted to rotate them to eliminate that possibility, but they found that one of my rear wheels had a slight lip bend on it.
So.....going to get the bend fixed next week........then......rotate the tires.......if that does not work......I guess I'll try the camber kit.
I am told that drift can sometimes be fixed by a Road Force balance.....but 99% of the time its an alignment issue.
Long story short, been having this problem for months. I installed new front and rear pads, had them resurface front and rear rotors, but shake is still there. It's ridiculous. I decided to save for new drilled & slotted rotors, and new struts to be changed all at once. If it does not go away, then I'll get new brake calipers and install steel braided brake lines, then let the mechanic deal with a possible rack and pinion or hydraulic issue. I'm trying to get this thing to last more than 200,000 miles, this rattle and shake concerns me because the steering wheel and brake pedal is getting a good workout, which in my inexperienced, non-mechanic opinion, does some damage to the body of the car. I define my shimmy as 1/8 inch side to side movement of the steering wheel while driving and when breaking, half inch side to side movement. Hopefully this will be the cure: http://forums.maxima.org/group-deals...nes-fluid.html Just my $.02...
my personal experience is having a solid wheel balancing solves it. But certain roads no matter what will be noticed. Air pressure changing affects it. Resurfacing rotors will not help. If the rotors are not balanced from the start, nothing you can do but replace with better ones.
Driving with and without my plastic shield had no influence what so ever. It is an aerodynamic piece. It does not affect the balance or vibration of the suspension whatsoever.
ed571
Feb 5, 2001 08:15 PM
