I need some serious help... pretty frustrated
Old Mar 26, 2008 | 03:21 PM
farzin1's Avatar
I bought 6k HID conversion kit. Me and my Buddy took the bumper down removed the oem headlights and everythin. We pluged the HID cable to the battery, ground the black, hook the cables to the balasts, and put in the bulbs in. But for some reason the bulbs will not turn on. You guys had any problem with the bulbs not turning ON?
Plz help. it is very frustrating
thx
Old Mar 26, 2008 | 03:30 PM
jingiko's Avatar
did you try reverse plugs?
like black with red etc.
trial and error helps
also make sure you dont touch the bulbs when installing =]
Old Mar 26, 2008 | 04:14 PM
KCMAXX's Avatar
KC's FINEST
I would have unhooked the battery first...
Check the fuse panel?
Old Mar 26, 2008 | 05:01 PM
farzin1's Avatar
what do i check for at the fuse panel?
and what do yo exactly mean unhooked the battery first?
thx
Old Mar 26, 2008 | 06:12 PM
KCMAXX's Avatar
KC's FINEST
I mean before I dropped the bumper and messed with the lights I would have disconnected the battery.
Since you asked, im assuming you didn't.
You may have arced a wire somewhere or who knows what. Pull the fuse panel off and find the headlight fuse. You might get lucky.
Good luck...
Old Mar 26, 2008 | 07:40 PM
!PrjctMax!'s Avatar
Did you turn the switch on...?
Old Mar 26, 2008 | 08:20 PM
farzin1's Avatar
I grounded the black cable instead of hooking it to the battery(negative). should i try hooking it to the battery this time instead of grounding it?
Old Mar 27, 2008 | 07:06 AM
max_n00b's Avatar
I just had 4300k HID kit installed with no problems. What I can tell you from experience after installing many of these kits on cars is that it is simply a trial and error game.
I would suggest just trying plug and play and don't hook up the kit to the battery at all to see if it works that way.
1) Check all connections and double check.
2) Make sure ground is a good one.
3) Last resort you will need to possibly buy another kit and test a different bulb.
Old Mar 27, 2008 | 06:17 PM
CanadianMoFo's Avatar
Pull it out and test it on the battery terminals.
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
