Yes... another PO113 failure :(
What up homies (And Larsim lol)
Ok I might have lied a little so sue me (Cant hire Deus). My car has had a minor problem....
I have had this reading for maybe a good... month. PO113 Intake Air Temp Circuit High Input. I thought that maybe my IAT might be bad... so I actually bought a brand new one. Installed that, and maybe after a good 20 minute drive... light right back on. Plugged my OBDII in and same reading. I then noticed that my CAI is not actually stable. It was never bolted down and one side of my CAI is not even red anymore. The entire time...it was slamming against the Chassis. I see metal now on one side and I am hoping this is the issue. But could that actually through this reading?
Next week I plan on buying the Fujita CAI since I have heard no issues about it yet.
I wanted to know what you guys think before I do this though. I dont want to end up with a extra CAI also!! lol
Let me know homies!!
Just to throw something out there. Isnt IAT part of the MAF? And if your throwing the code have you tried to clean it or could you swap it out with someones before you buy it? Ahh just read you bought a new one. Have you checked the wires?
I have tried cleaning and nothing is working.
I am really not sure how to check the wires... I mean... what am I really checking for?
I am about 100% sure the wires are ok because the car is indeed running ok.
I did think of the sensor being bad but... both sensors are reading the same code.
Also... What do you mean by rubbing? What 2 items could I check for rubbing?
Ok I took a good look today and noticed that 3 of the five wires that is spliced into that connection holder that goes into the IAT were cut. I have no idea how but I am pretty sure now that this is the problem. ****!!!
The same thing happened to one of my previous whips and I never figured out why it happened!!! Glad that at least now you know what it is!
I fixed it YAY YAY YAY!!!
I bought a $17 soldering tool and some $6 electrical soldering wire and re connected everything.
It took me about an hour because I only had a razor for splicing. lol
Oh and I called the stealership to see how much something like this would cost...
They said roughly $400-$450. Crazy **** huh!?
In any case.... I have an extra IAT sensor just incase and also gained some more experience points.
When i called the stealer... they said that the connector is not sold as a spare. They said I would have to take it in... thats when I figured I do it myself. I honestly would still like to change it out if you know where I could get one.
The only place where people touch anything under the hood is where I always take the car for the performance installations.
I said that same... The electric covering did not look like a normal tear at all... It looked like something cut it. The rip was entirely to sharp for fraying or corrosion.
I might need to start looking for new shops out here on the Island now...
http://www.waytekwire.com/automotive-wire-connector.htm
http://www.sherco-auto.com/cg.htm
Havnet looked for anything like that in awhile. Maybe try here.
Looks more universal but something can surely work. I'll see what I can find.
At least you got it fixed cheap. I would stay with the factory connector(they are normally more solid and watertight) as long as you soldered all connections and sealed them tight.
Factory huh!? Yeah its holding good so far and the fault cleared on the OBD II. I will take a pic of the finished product later today for you homies.
The Wizard
24
10-01-2015 08:47 PM
