Driver side window issues...
Old May 17, 2008 | 08:13 AM
Dayle97SE's Avatar
My '04 Max was broken into recently and I had to have the driver window replaced. Now however, since the window was replaced the automatic up/down feature doesn't work. The roll down feature with the remote does not work either. The passenger window still works fine with those features though. Is there some sort of reprogramming needed? And if so can I do it myself? I'd really rather not go to the dealer if I don't have to.
Old May 17, 2008 | 09:40 AM
Apollos2's Avatar
I'd go back to who ever replaced that window and tell them to fix it. Sounds like it worked fine before you had them replace the window.
Old May 17, 2008 | 06:12 PM
farzin1's Avatar
i have the same problem. After i replaced that passenger side i cannot roll the passenger side window down, or someitmes it will roll down but it wont go back up. which is kina gay. i took it to a couple of different places and they said it can't be fixed. which is even gayer.
Old May 19, 2008 | 11:26 PM
po8pimp's Avatar
B.S. find the post on the Led door handle installation and you can see all the components in the door and how they work together. sounds like something wasn't plugged back in when they removed the interior door piece. to replace our windows is a piece of cake and takes no time at all. like 5 minutes at most to remove and maybe 8 to put it all back together. check it out I am sure it's an easy fix. Good luck if you need help im me I will provide wiring diagrams if needed.
boomerbrian
Oct 31, 2018 10:25 AM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
maximusrising
Sep 2, 2015 09:55 AM
