Thermal Spacer Experience
Old 07-18-2008, 07:02 PM
xorbitman's Avatar
Hi! Now that some of you out there have installed the thermal spacers (NWP Engineering) for a while, what has your experience been with them?
1. Power
2. Noise or Sounds
3. Any Issues
4. Warranty
I am thinking of installing it in my 2005 SE and would like to see some feed back on the subject before I dive in head first. Any responses would be welcome and appreciated.
Thanks,
xorbitman is offline
Old 07-18-2008, 07:13 PM
wyche89's Avatar
1. Power
2. Noise or Sounds
3. Any Issues
4. Warranty
Thanks,
i dont have them, but all experiences that i've heard have been positive.. good power increase.. i heard you can even touch your IM after a long drive...
not that you would buy spacers just to be able to touch your IM, but you know.. lol.. just an observation
wyche89 is offline
Old 07-18-2008, 07:24 PM
xorbitman's Avatar
Nice ride WYCHE89! The hyper silver mags of that year MAX are still one of the nicest mags our there IMHO.
Old 07-18-2008, 07:28 PM
dstruc's Avatar
i bought mine 2 months ago and i still havent installed them. no money to do it. but i have heard it gives you a little low end power.
dstruc is offline
Old 07-18-2008, 07:39 PM
Hilbe's Avatar
I think they increase your gas mileage...just a gut feeling from using them since they came out.
Hilbe is offline
Old 07-18-2008, 10:15 PM
!PrjctMax!'s Avatar
Install is rather simple if you were to check out my sticky on how to remove the UIM.
http://www.6thgenmaxima.org/forums/viewtopic.php?t=5179
If one has a CAI, then adding the spacers adds a nice little hiss in a certain range. It reduces temperatures by 40 degrees which is a definite plus. Keeping the motor cooler will also give it more consistent power. A peppier motor is also funner...
!PrjctMax! is offline
Old 07-19-2008, 05:31 AM
madmik's Avatar
Only positive for me. A bit of whistling but I am planning to move the TB spacer a bit. I suspect its not centered well. I cannot comment about power. I ported both UIM/LIM, blocked the EGR by 50% and used the TB coolant bypass when I installed my spacer. Lots of power @ upper end.
Be sure your tech does not use too much of the Permatex gasket maker. Too much will ooze into the runners/ports and create a small restriction.
I kept the rear UIM backet on. Because the UIM sits a bit higher, the instructions say to discard the bracket. I simply cut the upper 'ear' of each upper hole with a dremmel to give the two upper bolt holes a 'U' shape.
madmik is offline
Old 07-20-2008, 01:57 PM
slvrmax7's Avatar
I've enjoyed mine for the 2 weeks theyv'e been on. I can feel a better pull 3500+ for sure. The whistle is easy to hear with my Berk short ram intake in, and I like it. Definitly a good mod for the price.
slvrmax7 is offline
Old 07-20-2008, 04:37 PM
KC2010's Avatar
I got the berk w/ nwp's as well. The car has much more pep in the low end but decreases over time due to the ecu compensating. A TS on the ecu would be nice to really get the biggest bang for the buck out of the nwp's. I did get 19 to 20 mpg on highway prior to the berk/nwp install. Now I get 28 mpg with a light foot. key: light foot
KC2010 is offline
Old 07-20-2008, 04:40 PM
Elite6's Avatar
Why does the power increase, decrease over time? Is the stock Ecu that much of a babysitter?
Elite6 is offline
Old 07-20-2008, 04:45 PM
KC2010's Avatar
Stock ecu is always trying to maintain stock parameters. I do see a performance enhancement but more when I first had the sensors aligned. Just like Chernmax and a couple of other orger's have suggested we should get a piggyback system and a dyno tune to get the most out of our mods.
I would have to say, so far, the NWP's have been my favorite mod. A great product, and man, the customer service Aaron provides, like no other.
KC2010 is offline
Old 07-20-2008, 07:52 PM
slvrmax7's Avatar
That's funny you say that, I was just driving with my girl today and was saying i thought, MAYBE, the car seemed a little slower. IDK if it's my imagination but I can tell the max needs a tune. At low end it's a little sluggish when downshifting in auto mode. Anyways I know were both getting headers when they hit the market, soon fingers crossed, so I'm gonna wait it out. I wonder what others are thinking for the best tuning options when headers get installed...........???? Please CHIME IN!!!!!
slvrmax7 is offline
Old 07-20-2008, 08:42 PM
xorbitman's Avatar
I'm not sure that you will see a bit benefit adding headers in H/P after the spacer.
Just my 2 cents.
Old 07-20-2008, 08:49 PM
xorbitman's Avatar
Does the ECU reprogram help the power loss problem? -> key in ignition in acc mode (engine still off) pumping the gas pedal 5 times after waiting 2/3 seconds and then waiting 6/7 seconds and flooring the gas pedal till the SES light starts to blink then taking the key out and then starting the car.
I think this helps, as the ECU is required to reprogram itself. You usually have to redo this every 200 - 300 kms (120 - 200 miles) once every two weeks.
Anyone care to comment on this?
Old 07-21-2008, 06:08 AM
KC2010's Avatar
I paid to have my sensors aligned. The relearning procedure reads like it's some type of sheet music and your car is the instrument. If I can't play rock band I doubt I could do the procedure correctly. Let's just say I paid for a little confidence that my car will run correctly. When I go in for my tranny flush I plan on paying for an intake cleaning and realignment.
I think anything we do to these cars we'll need a piggyback to see the optimal benefit. There's plenty of threads on this site debating it. I've gotten a headache going thru all of them!
KC2010 is offline
Old 07-21-2008, 08:04 AM
slvrmax7's Avatar
Just my 2 cents.
Sorry, why do you say that?
slvrmax7 is offline
Old 07-21-2008, 03:54 PM
xorbitman's Avatar
Aaron could probably answer that better than I could.
Old 07-21-2008, 06:48 PM
slvrmax7's Avatar
Alright, Ill'e get his thoughts.
slvrmax7 is offline
Old 07-24-2008, 09:10 AM
dot dot dot ...
NmexMAX's Avatar
Good Lord
NmexMAX is offline
Old 07-24-2008, 12:44 PM
Shizzle-Shane's Avatar
LMAO
Shizzle-Shane is offline
Old 08-18-2008, 06:58 PM
cfr94's Avatar
Well i know it's been a while since someone has posted, but I installed mine this past weekend. I lost all my settings (avg MPG, avg MPH, power seat settings, etc) because I disconnected the Negative battery. No worries there, I knew it was going to happen. Installed it on the 08 SE with a Racingline Performance FSTB. I had to take it off to get to everything, but once back on, you'll have about 1/4" clearance. Now onto the good stuff. I also installed the VIAS plate. I won't be able to tell any gains for MPG until my TDY to Texas next month. I had a friend come over to help and it went pretty smooth for the most part. Hardest thing was ensuring that everything was disconnected. I have noticed some gains around the 3500-4000 range. I did have some idling problems, but you'll only notice this if your A/C is off. It will drop to below 700. I feel this was an excellent buy. Aaron, good product for sure. I didn't take pics, sorry guys, but it's on with less than 12,000 miles on a car less than 10 months old.
cfr94 is offline
Old 08-18-2008, 08:08 PM
!PrjctMax!'s Avatar
If you disconnected the harness on your throttle body, then you have to get your idle reset, which is why you are having issues with that.
Old 08-18-2008, 08:28 PM
dstruc's Avatar
how long did it take you to do all that. i have an 08 too but cant find the time to install mine. its been like 3 months now.
dstruc is offline
Old 08-19-2008, 08:35 AM
KC2010's Avatar
It's about 100 bucks at the dealership. After that, WOW! What a difference in the power! Nice low end enhancement.
KC2010 is offline
Old 08-19-2008, 11:26 AM
Apollos2's Avatar
I have a whistling with mine, it's worse with the AC running. Mostly I can hear it at start up and idle. I'm going to talk to my tech and see what can be done. Maybe my install was off or something. It's getting a little annoying to me. I mean the car looks good, I like it to sound good too.
Apollos2 is offline
Old 08-25-2008, 06:16 PM
CanadianMoFo's Avatar
Finally got mine installed today. A bit of whistling under load. Pretty quiet otherwise. I don't really notice it unless the radio is off and I'm on smooth pavement. It really is a nice upgrade. Well designed kit. A bit of gains in the mid/top end. Well worth the $$'s.
CM
CanadianMoFo is offline
240tomax
Tires and Wheels
02-10-2016 11:01 PM
MaxLvr21
10-17-2015 12:11 PM
coolsun
Wheels/Tires
10-15-2015 10:52 PM
Pied
09-26-2015 03:29 PM
TxBroncosFan
09-21-2015 06:54 PM
Quick Reply: Thermal Spacer Experience
