Install of APexi Neo
Old Aug 6, 2008 | 10:02 AM
Shizzle-Shane's Avatar
Does anyone have a wiring diagram for the 6th gen maxima or any input on wiring up the Apexi Neo which would be the same as the old Apexi AFC. Any help would be appreciated.
Old Aug 6, 2008 | 10:21 AM
NmexMAX's Avatar
dot dot dot ...
Use this as a starter:
http://www.mohdparts.com/emanage/ins...04AltimaEU.htm
All you need is MAF wire, TPS signal, RPM signal, Power & ground. Don't mess w/ the KS or O2 sensor wires.
And then go here:
http://forums.maxima.org/4740357-post2.html
Wiring it up is the same as any other AFC, but you need a pinout of your ECU, which is given in the first post. A smart thing to do prior to starting is downloading an FSM.
Old Aug 6, 2008 | 11:01 AM
Thanks for the help bro.
Old Aug 6, 2008 | 11:40 AM
redls1's Avatar
MAXIN' ON
Here is a link to the FSM if you need it.
http://phatg20.info/index.php?option...nc=select&id=1
Old Aug 6, 2008 | 12:23 PM
NmexMAX's Avatar
dot dot dot ...
Or here:
http://www.aubreyandcharles.com/NissanServiceManuals/
Old Aug 6, 2008 | 12:32 PM
Where can I find a pinout of my ecu? The first link you sent me was for 2002-2004 but I need one for a 2006. Any help?
Old Aug 6, 2008 | 12:38 PM
NmexMAX's Avatar
dot dot dot ...
That's what you get for not letting me know you had on 06
Old Aug 6, 2008 | 01:04 PM
My bad. I thought I did. Let me know if you can find out anything.
Old Aug 6, 2008 | 01:05 PM
NmexMAX's Avatar
dot dot dot ...
Why can't you just download the FSM and get the diagram for yourself?
Old Aug 6, 2008 | 01:09 PM
In the process of doing that now.
Old Aug 7, 2008 | 06:58 AM
NmexMAX's Avatar
dot dot dot ...
Use this only as a guide. But instead, you will need your own 2006 pin-out & wire colors.
I can provide this very same diagram for your 06 later today if you can wait.
Old Aug 7, 2008 | 07:49 AM
Hilbe's Avatar
Please post the 2004 for my reading
Old Aug 7, 2008 | 07:50 AM
NmexMAX's Avatar
dot dot dot ...
I can do both, they are probably the same tell you the truth.
Old Aug 7, 2008 | 12:02 PM
Thanks bro. I'm gonna take this to the shop now and see what we did wrong. Thanks again.
Old Aug 7, 2008 | 12:15 PM
Do you think you can find the one for the 06 or are you sure they are the same layout?
Old Aug 7, 2008 | 10:26 PM
NmexMAX's Avatar
dot dot dot ...
Working on it man .... Been dranking a little bit tonight, so it is takin' a smidgen longer...
Step 1, = provide pin out of said year(s) {04-08}:
Step 2, provide AFC pinouts w/ respective colors:
Old Aug 9, 2008 | 06:11 AM
Apollos2's Avatar
Post up some pics of the install once you are all done. I ended up mounting my control in the sunglass drop down. Let us know what you think of the NEO.
Old Aug 11, 2008 | 08:44 AM
I have it installed right now but I'm having issues with the correct pins to wire in the rpm and throttle features of the Apexi Neo. Anyone know anything on this? I was actually thinking of placing my piece in the Sunglass drop down as well...
Old Aug 12, 2008 | 09:09 AM
So I guess nobody has the Apexi Neo on their 6th gen in here huh...I'm feelin' a little lonely on this one....
Old Aug 12, 2008 | 08:01 PM
eK9aT10pSi's Avatar
comeon nmexmax, step 2 lol .....
Old Aug 12, 2008 | 08:09 PM
JRoX85's Avatar
newbie
u-tec or t5 for the win neo is a pita
Old Aug 12, 2008 | 10:27 PM
NiZMo1o1's Avatar
message RamBerg , he has the safc2 installed , im sure should be the same wiring, he might be able to help u if nmexmax hasnt chime in
Old Aug 13, 2008 | 08:42 AM
Can you explain that in newb terminology...
Old Aug 13, 2008 | 10:21 AM
NiZMo1o1's Avatar
http://www.6thgenmaxima.org/forums/viewtopic.php?t=5737
UTEC
http://www.turboxs.com/shop_prod.php?what_category=3
http://www.6thgenmaxima.org/forums/viewtopic.php?t=4610
TS
http://www.technosquareinc.com/
Old Aug 14, 2008 | 11:07 AM
NmexMAX's Avatar
dot dot dot ...
I've provided that information many o' times.
http://forums.maxima.org/6422772-post18.html
Also, it's easy to DL the FSM and reference the pins. Have any of you even attempted this?
Old Aug 14, 2008 | 12:03 PM
ramberg's Avatar
GrandPa
I didn't do the install, a member from nycmaxima.org did it for me. I will check with him to see if he has a wiring chart. He did a few 6th gens but I don't know about the Neo.
Old Aug 18, 2008 | 07:05 AM
bizzump....
Old Aug 23, 2008 | 12:00 AM
NmexMAX's Avatar
dot dot dot ...
Here's your Gerber Now use the SAFCII install from Jime (i.e. use common sense)
Since the A34 does not have a tach signal, I'm going to ASSume cyl 1-6 will work...
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
