Dome light.
Old Dec 29, 2008 | 12:04 AM
chris350's Avatar
Dome light.
Quick question guys, I just got some led's for my dome light for my 06 max. How do I open/get access to the blubs? Is it the one screw in the sunglass compartment and just pull it down or am I missing a step? Help.
Old Dec 29, 2008 | 10:22 AM
jsmithsole's Avatar
*moderator*
Take a small screwdriver (very small) and pop it open, or open the sun glass holder and pull them down from the back side. You don't need to pull down the whole piece, the lens comes right out...hope they're bright!!!
Old Dec 29, 2008 | 11:10 AM
Propa Teknique's Avatar
I got the 4-LED ones for the front and back dome lights... they look awesome.. I saw some 6-LED ones on Ebay that looked like they would fit also... They look really clean and are bright just like daytime light.... Hope you enjoy them. I just ordered the Vanity, Door, and Floorwell Lights for the interior also.
Old Dec 29, 2008 | 11:21 AM
Gollum67's Avatar
What type of LED's did you get? I've wanted to do this but since it was not high on my priority list might as well ask the Q. I want to do both front and rear domes.
Old Dec 29, 2008 | 12:45 PM
chris350's Avatar
thanks...so basically, the lense cover pops out with the help of a small flat head?
I got the super white led's from a seller from japan.
i also replaced the license plate light with white led's...they look awesome...
Old Dec 29, 2008 | 12:55 PM
I VIK I's Avatar
I think what ghollum meant was which LED's did you get size wise. These things usually have a number that tells us which size they fit (like all other bulbs) I would also like to know, please enlighten us.
Old Dec 29, 2008 | 03:21 PM
chris350's Avatar
i went to http://www.sylvania.com/ConsumerProd...de/default.htm and looked on ebay
http://shop.ebay.com/items/_W0QQ_nkw...romZR40QQ_mdoZ
^ that should be for the map light
http://shop.ebay.com/items/_W0QQ_dmp...3021&_osacat=0
^ for dome light
well for some reason or another i feel that those are the wrong types...i will have to get back to you guys in a few days...im still awaiting delivery of these said to be dome lights...
Old Dec 29, 2008 | 03:32 PM
chris350's Avatar
i have a feeling there like theses types
http://www.hid-lights.com/cat/LED-3156.htm
or theses:
http://www.hid-lights.com/cat/LED-3157.htm
something with a socket like light
if anyone knows...let me know..
Old Dec 29, 2008 | 03:48 PM
ILL-Maxima's Avatar
Let me know too, i was also thinking of doing my interior lights to white led and my number plate light to white leds...
Old Dec 29, 2008 | 05:51 PM
chris350's Avatar
the plates are the easiest. Just remove a few of the plastic fastners and pull back the liner on the trunk lid and you'll have access to the lights for the plate . the blubs are 168/194 for those...same blub but it goes by both numbers.
these also are the same blub types for the courtesy light for the front foot area....but the passerger side needs a LED with the lights on the side not facing foward....or as they are called...wide view LED's....
http://www.hid-lights.com/products/l...GP-194-5w.html
like those.....
Old Dec 30, 2008 | 10:35 AM
DownriteMaxin's Avatar
I am going to change mine whats my order comes in. I already changed my door lenses and I love the bright white light. Pics of the door lenses...
http://www.cardomain.com/ride/3162516
Old Dec 30, 2008 | 12:25 PM
jsmithsole's Avatar
*moderator*
Ok guys I have a GD going on LED's these are by far the best brightest lights out on the market and they are guaranteed for life! Here's the ink:
http://www.6thgenmaxima.org/forums/viewtopic.php?t=5913
note: comes with 3 connectors (194, festoon and bayonet (which we don't use))
These come in either white or blue (your choice)
Here's the blue in the floors and whites in the domes....
Hit me up!!!
Old Dec 30, 2008 | 03:00 PM
I VIK I's Avatar
So we would need 2 map lights and 2 dome lights correct, and then 4 door lights.
Old Dec 30, 2008 | 03:57 PM
jsmithsole's Avatar
*moderator*
And the 2 floor lights if you want to replace them as well...my link packages them up well and makes them easy to buy!!!
Old Dec 30, 2008 | 09:32 PM
PeaMAX's Avatar
Hey guys, where can i get those clear lenses fo the doors?
Old Dec 30, 2008 | 10:30 PM
morteljc's Avatar
check this link.... i dont know if it will work and if he still has it..... i got mine from nizmo101....
http://forums.maxima.org/6th-generat...door-lens.html
Old Dec 31, 2008 | 08:15 PM
po8pimp's Avatar
careful with those type of dome lights. I purchased some led replacements from JP and put them in and they didn't go completely off when I shut and locked the door and then killed my battery during shipment to Hawaii from Seattle. Didn't realize it even at night because of my tint on the windows and how dim the lights where when "turned off". I had forgotten my phone one night in the car, after I got here and already bought a new battery, and noticed the dome lights were lit very dim. so I ripped them out and checked voltages and resistances. Nothing was wrong with the wiring or the bulbs. So I went to Nissan the next day and talked with the tech who told me that the car was wired in series not parallel, so I had to change my floor led lights to regular bulbs in order for the dome lights to completely shut off.
Old Jan 14, 2009 | 09:26 PM
saxguyck's Avatar
What about that little light in between the map lights? I can barely see any light coming out of that little sliver. is there a way i can make it so there is actually some "mood" lighting coming out of there? anyone know what i am talking about?
Old Dec 12, 2018 | 04:28 PM
john2001au's Avatar
Thanks for the tips to get access to change the dome lights. Best I used a very small 2.4 mm flat precision screw driver. At the hinge side slowly lift the front end and then the rear end of lens. Likewise lift the switch side last. Comes out easily and replace pushing in the reverse order.
Scott1243
Nov 6, 2015 10:55 AM
knightsh
Mar 6, 2010 09:50 PM
MrDicks95SE
Oct 13, 2008 11:17 PM
KJS2023
20
Jun 20, 2008 11:01 AM
lalaMAX
41
Dec 13, 2006 12:10 PM
