Max Won't Start....
Old Mar 18, 2009 | 07:30 AM
Red96MaxSE's Avatar
Max Won't Start....
Hi Guys,
Here's the scoop-- buddy has an '04 Max-- bought after I raved about my '96-- with a little less than 50k.
Got in this am, turned the key, and nothing. Wouldn't turn, no dead battery clicking, nothing-- like a total system failure. It had power-- battery was replaced 3 months ago, all lights are on, accessories work-- and everything seems "normal". Tried a few more times and still nothing. Waited about 15 minutes, tried it again, and it finally started as normal. Drove it around all am & still starting just fine.
Any ideas? Anyone else having this issue?
Old Mar 18, 2009 | 07:32 AM
Playa_FL's Avatar
Starter solenoid maybe?
Old Mar 18, 2009 | 12:41 PM
Fiddy Yen's Avatar
check your headlight fluids... they are prolly draining your battery.
I actually vote starter as well. I assume no codes? isn't this another common problem among maximas?
Old Mar 18, 2009 | 01:36 PM
Steve99Max's Avatar
Security light/Computer chip
Weird thing happened to me last week.... My 99 Maxima would not start. It would crank, but not turn over. No clicking. Lights, radio and other electronics worked. Had it towed to a garage a couple blocks away.
They couldn't get it started, but they noticed that the security light was lit when they tried to start it. Somehow the computer chip in my key was not recognized by the car's computer and no fuel was getting to the engine (anti-theft measure).
I called AAA to get it towed to the dealer so they could reprogram my keys. AAA called out a locksmith to reprogram my keys. After resetting the codes, she started right up.
Old Mar 18, 2009 | 01:54 PM
KCMAXX's Avatar
KC's FINEST
Tighten the battery terminals.
Old Mar 18, 2009 | 07:27 PM
Red96MaxSE's Avatar
Yea, I was thinking starter sol. as well. I had not thought of the "key" idea, so we'll check that one out, too.
Thanks for the responses!
Old Mar 19, 2009 | 06:45 AM
po8pimp's Avatar
10 to 1 not the Alarm system. Starter solenoid maybe. I vote Camshaft Position Sensor. Happened to me multiple times till I finally got a CEL and pulled the code. Replaced the Sensor and all is good. I am starting to see a trend people. Here read these threads: http://forums.maxima.org/6th-generat...hs-et-all.html and http://forums.maxima.org/6th-generat...-start-up.html
Old Mar 24, 2009 | 02:42 PM
LucKie1nE's Avatar
Sounds like a starter..
Old Nov 8, 2009 | 02:32 PM
magicmattkelly's Avatar
Originally Posted by Red96MaxSE
Hi Guys,
I had this same issue with my 04 this afternoon for the first time and searched the forums and found this. My problem was slightly different. I had actually gone to the supermarket, went in and came out 20 minutes later - unlocked the car with the key fob, got in and went to start the car. Everything came on normally (dash lights, etc) but when I went to crank the engine, everything suddenly went dead - as if the battery had suddenly come unplugged. No click or anything. I turned the key off - turned it back on and still nothing. Popped the hood - battery cables fine and tight, very clean, no corrosion. Got back in, turned the key on again - the dash/warning lights came on again. Turned the key to start - everything went dead. Got out, wiggled cables, turned key off and on to no avail - I couldn't find a problem at all. I was about to give up when I tried one last time - everything came on and the car started normally, as if nothing happened.
My first though was maybe the chip in the key was going bad and I either needed a new key or maybe it needed to be reprogrammed - I say this because as I drove home, I noticed the red "security" light on the dash had stayed on. Got home, turned the engine off and the security light went out and returned to normal status. I noticed that the clock and trip computer had reset, so definitely something went awry with the battery connection but I can't figure out where. The car has been fine ever since - for now.
Any ideas? Negative ground to chassis looks fine. I don't know what to do other than wait for it to happen again, I don't want to rip the car apart to get to fuse blocks looking for bad cable connections if I don't need to.
Old Nov 22, 2009 | 11:31 AM
Well, no answers to my question - which is fine, because the problem hasn't happened since. Till today. In the parking lot of AutoZone, of all places. Since this is the first time I got the problem to recreate itself since the first episode, I left the ignition in the "on" position (figuring I'd hear the radio and relays click on once I got electrical continuity again) and opened the hook and started wiggling cables. It didn't take long. Neg cable was fine, but the positive cable to the battery was loose. Not "pull me off" loose, but loose enough for me to grab it and break contact to the battery. More concerning was that the terminal clamp was very rusty. I've seen corrosion on battery terminals before, but never rust (like it had gotten rain or road salt exposure) - probably contributing to a bad connection. Gonna hit the Nissan shop and get a replacement. Evidently between the time I used the remote to open the door and start the car, the shudder from closing the door on the car was just enough to jar the cable the tiniest bit. Anyway, happy(?) ending to an aggravating experience!
Old Nov 22, 2009 | 01:38 PM
DeusExMaxima's Avatar
I would clean the battery terminals and tighten the lugs tight. They dont have to be very loose to fail, as u found out. If you have full power but it doesnt start, make sure ur clutch is in all the way if ur a 6 sp manual. If ur an auto, make sure tranny is in park. Wiggle the shift lever some wile u try to start it.
Old Nov 27, 2009 | 10:04 PM
MaxEx's Avatar
I've had this happen to numerous vehicles. It was either the battery terminals or carboned up starter.
Old Jul 4, 2011 | 12:46 AM
Akiriyama's Avatar
Last week I was putting gas on my '04 and after I filled her up she wouldn't start, and the electronics wouldn't work either. After an SUV couldn't jump start it I called AAA and they were able to do it but the car died when I turned on the headlights. I got it towed home and replaced the battery the next day.
It worked after the replacement but the engine has died twice since, if only briefly. The electronics would work but the engine would shut off. But it would work again if I restarted it. Also, the security light stays solid if I lock it using the remote. Any ideas?
Old Jul 4, 2011 | 07:12 AM
Rsprince89's Avatar
Try telling the max your gonna sale him if he dosent get his **** together
Old Jul 4, 2011 | 07:37 AM
MaxPrime's Avatar
Vote for this one it happen to me befored.
Old Jul 4, 2011 | 09:51 AM
timpol's Avatar
What kind of voltage do you have before you start, while it's cranking, and then once it's running? Sounds like an alternator which if faulty has probably drained your battery
Old Jul 7, 2011 | 11:03 AM
Akiriyama's Avatar
I didn't check the voltage but just took it to my mechanic. Turns out the throttle body was gunky and stuff and needed cleaning. No problems with that in the hour that it's been since I picked up the car.
Old Aug 10, 2021 | 01:25 PM
uptownsamcv's Avatar
if it's only starting in neutral I think that's an issue with the neutral safety switch. I had a Nissan Stanza with that issue back in the day and I would just start it in neutral.
Old Oct 4, 2021 | 12:13 PM
geovani.kaesen's Avatar
Speed Test
sublime258
20
Oct 8, 2008 06:51 AM
MAXSE5SPD
May 8, 2007 05:49 PM
remykins
Dec 20, 2006 08:34 PM
zamac_man
Mar 23, 2005 08:58 AM
drakken789
Jan 5, 2004 08:13 PM
