Motor Mount Insert Issue
Old May 6, 2009 | 06:05 PM
GrimMax's Avatar
Where is my shirt?
Whats up homies!!
Recently I tried to get the MMI's installed by my shop out here in NY. They said that the MMI's were "slipping and popping" off everytime they tried to place them in. They decided to cancel the mod until I get some feedback from you guys. So for you guys who got the MMI's installed, did you have any issues also? Is there a certain way to get them installed?
I am auto 5-Spd BTW. Thanks fellas!!
Old May 6, 2009 | 06:34 PM
Puppetmaster's Avatar
What sort of inserts do you have? Energy Suspension? Regardless, any competent shop with a good machine press should be able to press them into the motor mounts. I don't believe I've heard many issues when taken to shops with a press. When Tilley (TILLEYS99) helped me with mine, he actually used a wall mounted spring compressor, couple 2x4s, and Crisco, and we were able to pop them in.
Old May 6, 2009 | 07:21 PM
NiZMo1o1's Avatar
You really need to play with them on the 6th gen.. The Racingline MMIs need to be sqeeuze it tightly , We did it by hand but we had to go caveman on it.. its a PITA but onces its in there your good, Didnt have to go thru a press or grease.
mines been on for 2 years
Old May 7, 2009 | 10:42 AM
slvrmax7's Avatar
Hey GrimMax let us know when you get them installed successfully and where, I've been dying to get these installed. Vipervadim might be worth getting a hold of if it's tough finding a shop though, IIRC he said he could def. help with it. Best of Luck.
Old May 7, 2009 | 10:58 AM
GrimMax's Avatar
Where is my shirt?
Not sure. I do have the racingline ones though.
Old May 7, 2009 | 10:59 AM
GrimMax's Avatar
Where is my shirt?
lol caveman huh!? Yeah my shop said that they just kept popping off?? Did you use anything to hold them on?
Old May 7, 2009 | 11:00 AM
GrimMax's Avatar
Where is my shirt?
Yeah Viper is trully an expert! I am gonna see him soon to rewire the O2 sim. I will def let you know when they are in and where. Thanks bro!
Old May 7, 2009 | 11:11 AM
Oh okay, nevermind then. Those are the ones that just fit into the gap in the stock insert, right? I've no experience with those, only the full insert replacements. Hope you get it worked out.
Old May 7, 2009 | 01:42 PM
Oolatec's Avatar
Had no problem with my front one... it just slid right in. *shrugs*
Old May 7, 2009 | 01:44 PM
NiZMo1o1's Avatar
I try to sqeeuze them on tightly..they will try to pop out ,, try to get it in the subframe and screw it in asap
Thats all i can remember because its been so long.
good luck
Old May 7, 2009 | 02:12 PM
blaxima06's Avatar
Sorry for my ignorance, but what is a motor mount insert? Whats the purpose for it?
Old May 7, 2009 | 04:07 PM
NiZMo1o1's Avatar
your OEM mounts have some play, by installing the inserts , its strenghs the mounts so your elimanate play.http://www.racinglineperformance.com...a46996ce6d53a2
Old May 7, 2009 | 08:00 PM
blaxima06's Avatar
Thanks bro for the info!
Old May 7, 2009 | 08:08 PM
yunior32's Avatar
??? hu chinesse to me lol
Old May 7, 2009 | 10:22 PM
NiZMo1o1's Avatar
Old May 8, 2009 | 08:10 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
PM sent, can be done...
Old May 29, 2009 | 10:33 PM
hecmaxi's Avatar
Where can i get replacement front motor mounts?
I'm looking to replace my front under the radiator. its has a sensor attached to it.
Old May 29, 2009 | 10:57 PM
DeusExMaxima's Avatar
I have had mine for a long time on the shelf so I need to get crackin and get these in.
Old May 30, 2009 | 06:39 AM
cfr94's Avatar
x2. You got the Racingline Performance MMI's also?
Old May 30, 2009 | 04:59 PM
NiZMo1o1's Avatar
your local nissan dealership or
http://www.courtesyparts.com/default.php
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
Maxima30
Sep 7, 2015 06:13 PM
intimidator
Sep 5, 2015 07:23 PM
