6th Gen Jet MAF Sensor
Old Mar 6, 2010 | 03:58 PM
  #81
cfr94's Avatar
Originally Posted by chernmax
I'm not sure you will achieve either, the benefits to date have been with the low end throttle response which makes the car start stronger and the low end launching of the vehicle (from a stop) feel like night and day!
An improvement to your throttle body position can achieve that and the vehicle can perform better but still maintain the same HP. This is the awesome part about this mod that most people are overlooking or discounting.
AH-HA......
Old Mar 26, 2010 | 10:58 AM
  #82
cfr94's Avatar
Installed! Disconnected the battery to ensure no CEL or additional codes. Took off the old one, installed the new one, reconnected the battery and started the car. No CEL and the car runs fine. I also changed my oil and added the traction bars from racinglineperformance.com while I was under there. The car sticks to the ground with the bars installed and the throttle seemed to be quicker and I didn't notice the lag you normally have when you accelerate.
Old Mar 26, 2010 | 12:06 PM
  #83
GrimMax's Avatar
Where is my shirt?
Nice Chris! Is this on the NYCMax yet?
Old Mar 28, 2010 | 06:17 PM
  #84
m_turner_02's Avatar
so is there any dyno numbers to support these claims? I am just curious how the maf sensor can increase throttle response....does in alter the voltage signal or what?
Old Mar 28, 2010 | 06:20 PM
  #85
redmaxpa007's Avatar
i SeE what you did therE
good luck getting any real numbers....
Old Mar 28, 2010 | 06:26 PM
  #86
I can dream right? .....don't tell me this place is getting as bad as NC
btw, I know I said I was out on our deal, but if you are still interested I will be passing through on the weekend of the 16th if it is still up for sale...just let me know
Old Mar 28, 2010 | 06:32 PM
  #87
hmmmmm.... i will let you know
Old Mar 28, 2010 | 06:34 PM
  #88
I will hit yo up in the next week or so before I head up and see where you are at.
sorry for cluttering up this somewhat pointless thread
Old Mar 28, 2010 | 11:26 PM
  #89
Oolatec's Avatar
There are no dyno numbers because this thing is just a sensors. A sensor will not do a damn thing to increase performance.
Old Mar 28, 2010 | 11:45 PM
  #90
chernmax's Avatar
Nations 1st 6th Gen Turbo
Put one in and see what happens then report back to this thread.
Old Mar 28, 2010 | 11:47 PM
  #91
chernmax's Avatar
Yes my NYC bros know also...
Old Mar 29, 2010 | 08:58 AM
  #92
Oolatec's Avatar
I'm telling you guys... it's all in your heads. Placebo effect. A simple sensor (that's identical to stock) won't do anything.
I'd put one on, but I doubt it'd fit the dual intakes on my G37xS...
Old Mar 29, 2010 | 10:16 AM
  #93
chernmax's Avatar
Well then thanks for playing...
But before you go, as a guy who actually does tuning, sensors can be reflashed like ECU's to make your car perform better. No one on this thread claimed any HP gains, I stated performance gains which is a distinct difference...
Old Mar 29, 2010 | 10:40 AM
  #94
Oolatec's Avatar
Oh, I'll still be around. You won't get rid of me that easy! lol
Yes, I definitely know! Dynos don't measure "better throttle response" though... when you tune, you tune the ECU, not any sensors themselves. Of course, you're boosted, so yeah, there's more of a chance for benefits with this thing given your application.
But for n/a people... it's a waste IMO.
And just so we're clear... Chern, you have been great for this forum, with everything you have done to your Max! It is definitely one of my favorite ones! Major props for all you've done for the community!
Old Mar 29, 2010 | 11:04 AM
  #95
chernmax's Avatar
Sensors can be remapped to tell your ECU different things, like a piggy back computer!
One thing is certain, we cool...
Old Mar 29, 2010 | 11:13 AM
  #96
Oolatec's Avatar
Fo sho! It's all good!
Old Jun 15, 2010 | 02:25 PM
  #97
rohanmax14's Avatar
I installed jet maf sensor today n I did not disconnect battery wire but it took me 5 min to swap it out n everything but I didn't feel nothing bec I did not floor the car all the way down.
Old Jun 15, 2010 | 03:08 PM
  #98
rohanmax14's Avatar
But I did not reset ecu do I really need to do this cause I have no cel on n so far I drove 40 miles.
Old Jun 15, 2010 | 04:59 PM
  #99
chernmax's Avatar
Reset the battery so the ECU relearns!
Old Jun 15, 2010 | 07:41 PM
  #100
NlSMOwhiteMAX3.5's Avatar
what is it exactly that has a positive effect by the ecu being reset? should i do this after installing a CAI? mine should be here in the morning? will this reset boost results a tad?
Old Jun 15, 2010 | 08:07 PM
  #101
chernmax's Avatar
Our engines are computer controlled, resetting the ECU will help the car learn the new volume of air coming in from the CAI.
Our cars are pre programmed with stock parameters so slapping in a CAI then turning the car on, the ECU will think something is wrong therefore most cars will throw a Check Engine Light. Resetting the ECU (disconnecting the battery BEFORE install) will ensure it doesn't, or you can wait 4-5 days while the ECU adjusts and the CEL should go out on it's own.
Old Jun 16, 2010 | 06:44 AM
  #102
NmexMAX's Avatar
dot dot dot ...
A dynosheet from JET is never ever reliable, we've been dealing with that for over 10 years back in the 4th gen days.
So no definitive dynos yet, or track times? How about MAF sensor airflow log comparisons? AFR data? IPW increases?
I can see if it was entirely new housing similar to this item.
http://forums.maxima.org/5th-generat...ci-system.html
http://forums.maxima.org/all-motor/3...n-maf-mod.html < Don’t be fooled by the 4th gen title, the thread goes into a lot more technical depth than just 4th gen, and covers some good bases regarding the function of a MAF sensor.
But, ithe JET is only a sensor, and there’s really not much to a MAF SENSOR without its housing, both functional or otherwise. 0-5v.
Now add a larger housing and maybe it be more believable, but as is, I don’t see anything really changing.
Old Jun 16, 2010 | 08:28 AM
  #103
Oolatec's Avatar
It really is just a re-branded OEM sensor.
Old Jun 16, 2010 | 06:20 PM
  #104
NiZMo1o1's Avatar
excatly what I have been trying to say/state all along , the MAF only works on voltage and I dont see any proof of dyno , it doesnt provide more turblunce or a bigger bore MAF / housing.
everyone is buying into a product and yet I have not seen any real black and white data.
Either way I am glad I will be gettnig rid of the MAF completely with the ProEFI
Old Jun 16, 2010 | 07:28 PM
  #105
STILLENGLE's Avatar
Will this work on the 5.5 gen's as well?
Old Jun 17, 2010 | 06:03 AM
  #106
NmexMAX's Avatar
dot dot dot ...
5.5 Gen MAFs are are different than the 6th gens ...6th gens use the same MAF as Z33's (350z) ITB's, no need for no stinkin MAF!
Old Jun 17, 2010 | 09:10 AM
  #107
NiZMo1o1's Avatar
ITBs on Boost / ProEFI standalone !! its comming soon !
Old Jun 29, 2010 | 12:19 PM
  #108
joffy's Avatar
I just replaced my MAF sensor at Koeppel Nissan and had a 60000 mile service. Now the car isn't shifting right and the service engine soon light is on. I'm like WTF? I have an appointment to take it back tomorrow. Hope they can straighten this out.
Old Sep 10, 2011 | 06:34 PM
  #109
athlon omega's Avatar
Would having this JET MAF sensor interfere with an Osiris Uprev tune or work with it? I'm getting my car dynoed tonite with the JET sensor and then the stock sensor. I was going to send the run files to Osiris with a list of mods to take into consideration in creating map files for the flash such as adjusting the A/F ratio and other things. I read how Chernmax's car had some difficulty getting past 4500. Can this happen to me as well? Thanks
Old Sep 10, 2011 | 09:08 PM
  #110
RAZ76's Avatar
There's absolutely no difference between factory and JET. It's a gimmick. It does not change anythign, it's waste of your dyno money.
Old Sep 11, 2011 | 09:30 AM
  #111
Oolatec's Avatar
This is just as bad as those eBay chips.
Old Sep 15, 2011 | 10:08 PM
  #112
I wasn't going to dyno the car to see if I had any gains from the JET MAF sensor. I was just asking if it would interfere with the Osiris Uprev tune. If so, I would put the stock one back on.
Old Jun 9, 2012 | 12:43 PM
  #113
xorbitman's Avatar
JET MAF vs Throttle Amplifier
I personally think this is a better solution that the JET MAF: Sprint Booster.
Slamrod
Sep 3, 2015 07:38 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
vanebecker
Aug 19, 2015 09:45 AM
