Brake light is on
Old Nov 15, 2009 | 09:22 PM
Rich96's Avatar
Brake light is on
My brake light stayed on after I left my house today - thought maybe I hadn't released the e brake all the way, but that wasn't it. Checked the brake fluid and its topped off. There was a little bit of sediment in the bottom of the reservoir though.
What else could it be? The manual says to go to a Nissan dealer........trying to avoid that route.
Old Nov 15, 2009 | 09:35 PM
DeusExMaxima's Avatar
Make sure parking brake is fully released. Make sure switch for parking brake releases as well.
Old Nov 15, 2009 | 09:45 PM
Rich96's Avatar
Parking brake is fully released, but I was unaware of a switch - where is it?
Old Nov 15, 2009 | 10:39 PM
Switch is inside by bottom of brake lever. U have to dig for it. That could be faulty or not releasing. Also could be short circuit in wiring.
Old Nov 16, 2009 | 08:25 AM
Rich96's Avatar
How do you get to it - disassemble the console?
Once you get there.....how do you test the switch?
Old Nov 20, 2009 | 06:58 AM
rcg9999's Avatar
CHECK YOUR BRAKE FLUID
Old Nov 20, 2009 | 09:57 AM
AEMAXIMA01's Avatar
He already did that.......
Old Nov 24, 2009 | 06:22 PM
DConrad2007's Avatar
Don't take chances with your life or someone elses.You don't have to go to the dealer, you can go to a Pepboys or a Goodyear, but going to the dealer ensures that they can properly diagnose your problem before it's too late.
Old Nov 24, 2009 | 07:33 PM
91nissanmaxima's Avatar
This has happened before...
lol it wont go out. and it'll kill your battery. What has happened is that the thing that is pressed when you stop pressing your breaks has broken off.. I suggest you check that because on my maxima that was the problem. All you have to do to fix it is get a nail and a bolt and put them in the place of where that break release was... That solved mine.. Hope thats the only problem with yours.
Old Nov 24, 2009 | 08:35 PM
timwdv's Avatar
Mine did the same thing the other day, after i inspected my brakes. As i took off my passenger front tire my brake pad was worn all the way down so i replaced them and my brake light turned off just my 2 cents.....
Old Nov 25, 2009 | 11:33 PM
zzznightmarezz's Avatar
do u also have battery problems???? if u do then ur belt is gone.... the AC compressor's belt.... cuz u have 2 diff belts.. it runs ur alternator also.. and im sayin this because mine was gone.. n then i had 2 lights on.. BATTERY and BRAKE... i got the belt changed n they both went away... just take a look n c if thats it.... GL
Old Nov 30, 2009 | 06:55 PM
Rich96's Avatar
I'm an idiot, but I got it figured out.
Brake fluid was low. I saw the two hash marks on the side of the reservoir while looking at it from the front. They are almost identical to the ones on my clutch reservoir....mine may be slightly different that others as I've had my clutch MC replaced. (Don't know if it included a new reservoir)
In any case...until I looked at the SIDE of the brake reservoir I didn't realize where the high and low mark actually are. The hash marks I saw are just part of the molding. When properly viewing the high/low marks I realized that I was low on brake fluid.
Yep, I'm an idiot. If you looked at my clutch reservoir you would only think I'm a partial idiot though as the high low marks are almost identical to those on the brake reservoir.
Old Dec 1, 2009 | 07:54 PM
CanadianMoFo's Avatar
So now the question is, why was your brake fluid low? Pad wear or a leak. Keep an eye out for changes. If the light comes on again soon most likely you've got a leak to take care of.
Old Dec 1, 2009 | 09:15 PM
Rich96's Avatar
Well because I had originally filled it to what I thought was the "high mark", it was low to begin with. But the pads are getting low...EBC Redstuff didn't last long at all. Not sure what I'll try next.....I've had about everything. Probably go back to Hawk or Axxis.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
