Throttle Body
Old Dec 3, 2009 | 12:21 PM
tucker's Avatar
Throttle Body
Ok, did the search and nothing came up. I did this on my 5th, 4th, and 3rd gen. I just got this and it still appears to have a throttle body. Electronic no cables (of course). Doesn't it have to be cleaned periodically? I'd like to see a procedure on it.
Thanks,
Old Dec 3, 2009 | 03:00 PM
maxprophet's Avatar
i would also like to see that!when my tranny started actin up the dealer gave me some bull**** about the throttle body .they "cleaned it up" but my **** actin up again .and tranny is garbage now.idk the connection
Old Dec 3, 2009 | 04:48 PM
NiZMo1o1's Avatar
Thanks,
eh Im kinda of misunderstand , you just got a 6th gen(DBW - Drive By Wire) , basically your asking can the throttle body be cleaned out ?
Yes you can spray and clean it.
You need to pull some codes
Most likely you own a 2004 5AT tranny.
how many miles is on the tranny ? its probally shot
Old Dec 4, 2009 | 06:44 AM
tucker's Avatar
Ok, thanks. When cleaning the TB, can the butterfliy be opened manually without screwing up the DBW electronics?
Old Dec 5, 2009 | 07:29 AM
04MAX_ILLIN's Avatar
NO! I did this and screwed my car up. Still driving with a CEL and slightly high idle bc of my stupidity.
Old Dec 5, 2009 | 02:43 PM
NiZMo1o1's Avatar
What did you do , and what codes are you throwing ?
Disconnected the battery for 15 mins , then tap the postive terminal on the battery once and then tighten it up.
It will reflash the ECU , sometimes the DBW gets stuck open and this is the steps to fix it.
This might be the same issue
Old Dec 5, 2009 | 09:28 PM
myer84's Avatar
That won't work either. I did the same thing and accidently tapped tha throtle plate. If you really don't know what you are doing, take it to the dealership and have them clean it for you. I had to take my car to get my idle re-adjusted. Idle, ecu, and throtle position re-learn did not work for me when I attempted to fix it my self. I also disconnected my battery overnight. I had to pay about $100 to get it fixed at the dealership.
If you choose to clean it yourself, don't spray directly on the throttle. Wet a clean lint free rag with TB cleaner and wipe the TB without touching the plate.
Old Dec 5, 2009 | 11:40 PM
NiZMo1o1's Avatar
what excatly are you guys spraying into it ? brake cleaner or tb cleaner ?
Old Dec 6, 2009 | 03:33 PM
po8pimp's Avatar
lol don't recommend using brake cleaner
Old Dec 6, 2009 | 07:28 PM
NiZMo1o1's Avatar
I use it all the time with no issues on all customer cars and my own.
Old Dec 9, 2009 | 11:15 AM
tucker's Avatar
Ok what we're aying is the TB has to be cleaned (properly) at the dealer right. There goes another owner maintenance job. Gotta shell out the big bugs now. That sucks...
Old Dec 9, 2009 | 12:29 PM
NiZMo1o1's Avatar
Why? unbolt the intake pipe , spray inside with brake cleaner and your good ,I dont understand why your taking it back to the dealer to do a 15 min job ?
Old Dec 9, 2009 | 01:15 PM
tucker's Avatar
To clean the throttle body correctly the flap and the flap seat need to be cleaned. The seat is where a lot of the dirt accumulates. Sounds like if you touch that flap she throws a code.
Old Dec 9, 2009 | 07:48 PM
NiZMo1o1's Avatar
not mines , but then again ive taken the whole TB apart from the allen screws.
I Belive Ive open the flap/TB plate as well before on the car without any codes.
Disconnect the battery before you do it then if your worry about throwing codes
Old Dec 10, 2009 | 07:36 AM
tucker's Avatar
Ok Myer, Nizmo says no problems if you disconnect the battery. Did you do that before you worked on the TB?? Nizmo when opening the TB plate, are you going against any resistance? A spring? maybe TB motor? It's not like throttle cables with a spring return.
Old Dec 10, 2009 | 03:11 PM
NiZMo1o1's Avatar
Just disconnected it from the TB and your good Chris Tucker ! spray it down with carb cleaner or brake cleaner. , Dont take go to the dealership and get ripped off
Old Dec 11, 2009 | 07:13 AM
tucker's Avatar
Thanks Nizmo, let me know if I got it right:
1) Disconnect battery
2) Disconnect connector going to TB
3) Remove TB
4) Clean with soft tooth brush, ok to manually open and close butterfly valve to completely clean both sides and seat.
5) Install TB.
6) With negative lead attached to battery, tap the positive lead once and reinstall.
Good to go right?
Old Dec 11, 2009 | 12:01 PM
NiZMo1o1's Avatar
3) Remove TB
5) Install TB.
Good to go right?
yes your good to go , you dont need to do #6 , thats only when the TB gets stuck open which is a common problem on the 350z/G35s
I havent seen any of them stuck on the Maximas and Altimas.
Old Sep 3, 2010 | 08:52 PM
sdmax's Avatar
I sprayed and cleand my throttle body withouth disconnecting the TB and now it the idle is high. I don't hear the TB adjusting itself when I turn the ignition switch off either. I think I may have damaged it. Does anyone know how to re-program the TB?
Old Sep 3, 2010 | 09:08 PM
Oolatec's Avatar
Drive to dealer. Pay them.
REDinLV
Aug 15, 2024 12:30 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
followthadollar
Sep 13, 2015 09:55 AM
