Maxima hard to start when warm - No Codes
Old Jan 11, 2010 | 06:52 AM
BlackSpeed's Avatar
Maxima hard to start when warm - No Codes **RESOLVED**
After returning from the stealership with a depleted wallet and an unresolved issue, I turn to the folks I should have turned to from the beginning. My Maxima is hard to start when warm and there are No Codes visible. Here is the rundown:
1. Car hard to start when warm (cranks for about 2 minutes before
turning over).
2. Car stalls about one mile into driving, after cold start
(happens more frequently after I reset the ECU).
3. No Codes read from the Stealership
4. Stealership replaced MAF but issue remains (used one)
5. Fuel Pump replaced
6. Stealership stated the ECU was reading odd temps ( -49)
7. Read the TSB regarding the Camshaft and crankshaft position sensors
but there are no codes to prove the case.
8. Tried two different set of keys to eliminate in issues regarding security
I have never publicly pleaded for anything in my life (except for this girl I use to dig in 4H camp) but now I have to --> Please Help!!!
Old Jan 11, 2010 | 07:40 PM
BlackSpeed's Avatar
If you had to start with changing one sensor, which would it be?
Old Jan 11, 2010 | 08:21 PM
BlackSpeed's Avatar
Pulled this from the TSB:
ACTIONS:
If you only have DTC P0340, replace only Bank 1 CMP (Camshaft Position) Sensor.
If you only have DTC P0345, replace only Bank 2 CMP (Camshaft Position) Sensor.
If you have both codes, replace both sensors.
For a "hard to start warm" incident, replace both sensors, even if you have no codes.
Refer to sections EC and EM in the correct Service Manual for sensor replacement
Guess I'll start with the Camshaft positon sensors ..
Old Jan 11, 2010 | 10:56 PM
athlon omega's Avatar
I would try the coolant temp sensor first. My 95 max had a problem similar to that with long prolonged cranks out of no where and changing out that sensor took care of the problem. The sensor was under $30 from autozone. Just a suggestion.
Old Jan 15, 2010 | 04:53 PM
floppynuts3333's Avatar
I had similar thing happen..but I eventually threw a code. It had weird hard to start problems, then stalled going around a corner. I did some research and replaced the front cam pos. sensor. Took like 2 minutes and worked like a charm. That was 2 years ago. I had cold start problems recently when it was freezing out. DID the seafoam treatment and fixed her right up. Good luck
Old Jan 15, 2010 | 04:56 PM
3Point5L's Avatar
the position sensors 1 are expensive and are no joke to replace. i had to change out mine 4th gen. maxima. the rear sensor was easy. it was the one under manifold that was a pain.
(crank shaft position sensors)
Old Jan 17, 2010 | 10:21 AM
BlackSpeed's Avatar
I am happy to report that the replacement of Both cam sensors fixed an issue that the Stealership could not diagnose.. Thanks to all present and past who has either posted or started a thread on this issue..
Old Jan 17, 2010 | 06:47 PM
Terrentius's Avatar
Sweet. Well done.
Old Jan 17, 2010 | 10:17 PM
po8pimp's Avatar
hopefully you got your loot back or put towards the sensors concidering they made you put all that money towards nothing. Or at least got your old parts back for resale.
Old Jan 18, 2010 | 02:35 AM
1hawaii50's Avatar
Sound like a story I had with a POS Lincoln LS. I had the car for 2 months and traded it in for my Max.
Old May 27, 2010 | 12:37 PM
shawnada1's Avatar
PICS
Originally Posted by Terrentius
Sweet. Well done.
Can you please describe to me where the bank 2 camshaft position sensor is located? A part number and/or a pic of the sensor would help also. There is not too much info on these sensors for the maximas.
Old May 27, 2010 | 12:46 PM
shawnada1's Avatar
BANK 2
Old May 30, 2010 | 02:12 PM
exit69's Avatar
Love my Maxima... but man they are problematic cars!!
Old Jun 5, 2010 | 11:41 AM
striderg3's Avatar
i love my maxima also. but loving it doesn't stop it from breaking down. i just replaced the first sensor. and now am having the "hard to start warm" bull****. hurray. another $117 on another sensor. thanks nissan, ur electrical parts are bull****. 3rd sensor in a year.
Old Aug 21, 2012 | 05:43 PM
bris04max's Avatar
I am with you here! Crazy for having so few miles!
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
02PearlSE
Oct 7, 2015 02:12 AM
Balkins
Aug 12, 2015 06:39 AM
dauntlessmax
Aug 5, 2015 10:29 AM
