for those with aftermarket headers..
Old Jan 29, 2010 | 09:44 PM
EVESNAKE1's Avatar
Just curious, did you lose low end torque after the install?? How long does it take for our cars ecu to re-learn? Reason I ask is it definately feels like I lost a lot of low end torque. I had the headers installed today. Reset the ecu and drove about 50 miles so far. High end definately pulls harder and much quicker. Before the headers I used to be able to peel out first and sec. gear in my auto. Now it won't even chirp the tires in first gear until the car hits 4k. Just doesnt feel right. I do have a check engine light and my rear o2's are not hooked up yet. I'm hoping the ecu will eventually compensate for the extra air flow. Also no exhaust leaks what so ever.
Old Jan 29, 2010 | 10:30 PM
Mr. Brett's Avatar
Another header thread.
Anyway, to answer your question, no. If anything, in all honesty, I felt a bit more torque in my low-end when I installed my headers. A lot more high end, too. Of course, I also put new plugs in as well, so that may have been part of it...
As far as the check engine light, try driving for a while. Mine went off today. No reason or rhyme to it. I've had the headers on for about four days, threw a light upon start-up, and all of a sudden it's just gone. For your secondaries, have you considered getting an O2 sim versus extending them...? You may still throw a light if the secondaries don't have a cat to monitor.
Did you notice any change in your gas mileage? Mine sucks now. But I think I may have botched up one of my primary sensors during the install...or my foot's just gotten heavier because of the louder engine.
Edit: Btw, I know I drive a 5.5 versus a 6th gen, but I figured I'd chime in, having just had them installed. I don't see how the gains and install would be too horribly different between half a generation...
Old Jan 30, 2010 | 12:52 AM
EVESNAKE1's Avatar
No problem at all. Any advice helps so thank you for chiming in. Did you feel the power increase right away?? I was going to go the sim route, still unsure as to what im going to do. I'll wait a couple days and see if the power comes back.
Old Jan 30, 2010 | 08:42 AM
I3LAZEN's Avatar
You may want to check out the JET MAF SENSOR. I have a 6.5 gen & i bought that sensor & installed it. After resetting the ECU with the MAF installed.. the low end was increased big time. There's no lag when you pull off or anything. It just gets up n GO!
Old Jan 30, 2010 | 09:14 AM
nyana107's Avatar
^ what he said.
Old Jan 30, 2010 | 10:50 AM
RAZ76's Avatar
Maybe get a hand held programmer and set everything or custom tune. No point in replacing all those and not get a tune at the end. You got to remember that your car breathes different now. That's why Im waiting until next year, so I can do all my intake and exhaust at the same time.
Kinetix intake manifold
Nismo CAI
Jet Maf Sensor
Cattman Headers and Y-Pipe
Custom CB
Magnaflow resonator
2.5" mandrel bend piping.
Bully Dog Performance module chip
Old Feb 2, 2010 | 12:02 PM
xorbitman's Avatar
The ECU will reset itself after a couple of days and the light will go away however the code may still be there...and the SES will eventually light up again....you'll see.
Old Feb 2, 2010 | 06:46 PM
EVESNAKE1's Avatar
Check engine light will stay on because my rear o2's are not plugged in. I had the codes pulled and its showing for bank 1 and 2 rear o2's. Everything else is fine. I just had a resonator put in today to quiet things down a bit. It helped tremendously with the rasp I had. Got a lot of low end torque back and high end still pulls hard. I have a high flow cat on the way after that gets installed I will have my rear o2's plugged in and go from there. Changing my plugs out in 2 weeks to some iridium plugs 1 step colder. Thanks again guys for all your help.
Old Feb 3, 2010 | 09:28 AM
xorbitman's Avatar
I went with Iridium spark plugs after I installed my NWP spacer and via plate....If you''re going to open it up to change the plugs, I recommend the spacers!
BTW - My sparks are awesome...I get no lag when I thump it.
Old Feb 3, 2010 | 10:21 AM
EVESNAKE1's Avatar
Do you have the exact part number or heat range for the plugs you used?? Thanks Xorbitman.
Old Feb 4, 2010 | 10:10 PM
xorbitman's Avatar
I'll dig it up...it's been a while. I bought them off a friend who is a Nissan Performance Disti here locally.
I never could have imagined that the combo of 94 Octane and these Iridium plugs could be so awesome.
chisam14
Nov 6, 2018 08:56 PM
bigdogsteve
Jan 31, 2018 04:18 PM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
