Spark Plugs
Old Apr 20, 2011 | 08:16 PM
  #41
mrloren's Avatar
K & N filters are good filters. I don't use one and never want to. Your plugs look like what my friend who use to work for a filter maker said they would. This what he told me, Your car will suck the oil right up and if they dry out then you are in even more trouble. just buy a WIX and replace it every 10k.
  #42
rocketship's Avatar
Originally Posted by Terrentius
Also, I wonder if some of that oil might be from your K&N filter. You say, "Also clean and reoil K&N Filter every 5K," and you are now at 49k. Do the math, it's almost 10 times that you have lubed up your filter. Some of that oil is invarilby going to get down in there, especially if you are generous with the lub.
That is exactly what I thought but I checked the tube going to throttle body clean and dry inside.
Anyway done now like night and day difference which i did not expect.
Rough Idle GONE. Lag Gone.
Set speed control @ 65 and was getting 28MPG with a computer reset @65 so we will see, Same before was 23Mpg.
Throttle body and Manifold also Cleaned like new.
and NGK Irridium Plugs.
Throttle is instant now runnung great.
One thing I did notice was Nissan Gorrilad the spark plugs WAY too tight.
I will check the gaps on the old plugs tommorow and let you know.
Also engine threw 4 codes on restart. I cleared them and drove 15 mins they did not come back.
Old Apr 20, 2011 | 09:51 PM
  #43
Rsprince89's Avatar
Dose Nissan make performance spark plugs for a 08 max?
Old Apr 21, 2011 | 05:00 AM
  #44
rocketship's Avatar
Apparently these NGK Irridium Plugs are it. I was reading for every 100HP over stock go a step colder though.
Old Apr 21, 2011 | 05:10 AM
  #45
Terrentius's Avatar
Great; sounds like you made some serious headway that justifies your hard work. Yeah, if the plugs were too tight, then they were too far into the combustion chamber...making them more of a "cold" type of plug than they actually need to be. Hence, possibly the lower performance overall. The torque specs are very important and are factory calibrated for the characteristcis of the chamber/fuel/air.
Again, congrats on the benefits of your hard work.
Old Apr 21, 2011 | 05:18 AM
  #46
Terrentius's Avatar
If you really want to add, or I should say maximize, the performance of your engine, then cut the overall weight down of the car. Get the crap out of it. You can also cut some serious weight with new rims/wheels. The resistance that the stock wheels place against the inertia that is generated by our engine is over the top. Nissan would certainly do better to figure out some lower weight rims to add to the overall performance of the engine. For instance, my winter steel rims weight almost half as much as my summer stock rims. Kind of sad and certainly noticeable with acceleration from a dead stop or while already in motion.
Old Apr 22, 2011 | 12:19 AM
  #47
rocketship's Avatar
I have a bunch of crap in the trunk its got to go. I wanted to do just a few mods.
Old May 2, 2011 | 01:48 AM
  #48
blackmaxsl's Avatar
i would get oem one
it's nothing but spark plug
when you turn it on and that's it nothing more than that
i wouldn't pay any extra for aftermarket one
Old May 6, 2011 | 05:13 PM
  #49
Kryogen's Avatar
I did it and kept same gasket, was fine at 140 000km, no problem.
used NGK iridium. Absolutely no difference over 140K used plats.
Old May 9, 2011 | 09:16 AM
  #50
DMAXI06's Avatar
Originally Posted by blackmaxsl
i would get oem one
Do you know how spark plugs work bud? They fire continuously with the cylinder. They play a role in performance and gas mileage. Your probably thinking of a starter.
Old May 12, 2011 | 05:00 PM
  #51
xorbitman's Avatar
NGK Iridium...the best...Period!
Old May 12, 2011 | 09:53 PM
  #52
Ruiz2728's Avatar
You just inspired me to do the same to my newly aquired 04 se 6-speed. I live in NYC where the price for regular gas is 4.30 and its really hurting me at the pump. at this point i am willing to do anything to improve MPGs. you mentioned you had enough pics for a write-up, you game?
Old May 13, 2011 | 04:06 AM
  #53
Kryogen's Avatar
whats the diff over regular plats? I dont see any.
Old Jun 14, 2011 | 04:52 PM
  #54
wrestler760189's Avatar
what about E3 spark plugs arent those good also? whats the differcen between them and the other spark plugs??
Old Jun 14, 2011 | 05:34 PM
  #55
Kryogen's Avatar
its all BS, get OEM, they work.
Old Jul 18, 2011 | 02:47 PM
  #56
pocholin's Avatar
I know everyone here likes the NGKs, but I put Bosch Platinum 4 in my car 30K miles ago and I love them, no problems and excellent gas mileage, 100% street driving, with heavy foot I get 18MPG, only freeway at ~70mph I get 28MPG...can't complain.
Old Jul 18, 2011 | 04:06 PM
  #57
Kryogen's Avatar
I put ngk iridiums and cleaned TB and whole manifold. Reset the ECU and did all learning procedures.
Made absolutely no difference at all, in either idle, performance or fuel.
It was fine, it's still fine...
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
