2007 Headlight painting
Old 06-04-2011, 07:16 PM
dee.signs's Avatar
Has any one taken apart a 07-08 headlight housing to paint it, and if so how does it look now??
dee.signs is offline
Old 06-04-2011, 07:53 PM
hero782's Avatar
I have, twice to be exact
Here's how my headlight look now
hero782 is offline
Old 06-04-2011, 07:54 PM
RAZ76's Avatar
Before:
After:
RAZ76 is offline
Old 06-04-2011, 10:15 PM
twentyeggs's Avatar
did you use niteshades?
is that just one coat?
twentyeggs is offline
Old 06-04-2011, 10:30 PM
RAZ76's Avatar
You gonna plastidip them . Use high heat paint inside your heads, at least that's what I used.
RAZ76 is offline
Old 06-04-2011, 11:30 PM
6.5affiliate's Avatar
You can use high temp paint OR you can use krylon fusion, Duplicolor, Rustoleum, etc. Make sure you apply 3 coats of each (primer, base coat, and clear coat) and you should be good.
6.5affiliate is offline
Old 06-05-2011, 12:33 AM
twentyeggs's Avatar
oh . good one!!! you so fuuuunnyyyyyy
Old 06-05-2011, 12:37 AM
Gotta correct myself. With the Krylon Fusion, you don't need primer. Just spray it on, sand it in between coats and clear it. Easiest out of the three to use. Looks pretty good too. Here's a pic of one of my earlier designs:
This is NOT what it looks like now though....
Old 06-05-2011, 12:47 AM
twentyeggs's Avatar
hey how difficult is the taking the head lights off the car? particularly the passenger side... im planning on doing it but i want to know what im going to be in for.
Old 06-05-2011, 12:52 AM
hero782's Avatar
Just remove the bumper, I can do it in like 10mins
hero782 is offline
Old 06-05-2011, 01:00 AM
It's easy as hell. I'll pm you with all the info you will ever need on this subject.
Old 06-05-2011, 01:03 AM
twentyeggs's Avatar
sweet
Old 06-05-2011, 11:28 AM
I3LAZEN's Avatar
http://forums.maxima.org/6th-generat...ml#post8070852
I3LAZEN is offline
Old 06-05-2011, 01:34 PM
RAZ76's Avatar
Not as easy as ricing the car out with plastidip.
RAZ76 is offline
Old 06-05-2011, 10:04 PM
Pinto's Avatar
do you have more pics of the headlights this way? kinda what i have been thinking for my car. do you guys just paint right over the yellow lens?
Pinto is offline
Old 06-05-2011, 10:34 PM
Yup, here's a couple more pics:
If you mean the sidemarker than all I did was scuff it up with some 800 grit wet/dry sandpaper, primed it with some Duplicolor Adhesive Promoter and painted it.
Also, if your gonna use Krylon Fusion than you don't have to sand it at all. Just spray it and finish it with some clear coat. Easy as pie.
Old 06-06-2011, 01:48 PM
tweets04's Avatar
I went way darker with mine but it was easy. Front and rear was a 3 hour job not including dry time. Im not sure the brand of paint my buddy used but we learned not to use reducer in it. Thinner works better and wont cause that spider web like cracking that reducer can do to plastic.
tweets04 is offline
Old 06-06-2011, 04:43 PM
pics?
Old 06-09-2011, 03:49 PM
tweets04's Avatar
Will get some taken. I have a gold max and the headlights are almost a rootbeer color in the sun. Taillights are blacked out.
tweets04 is offline
Old 06-09-2011, 04:11 PM
tweets04's Avatar
I work in the country so dont mind the dirty car. Also need to buff the lights to finish up. But I like how they look.
http://
http://
http://
All lights are painted
tweets04 is offline
Old 06-09-2011, 07:28 PM
That looks GOOD man. Think it's the first one I've seen on the forums in that color with painted headlights. Like how the tails came out too.
Old 06-10-2011, 07:22 AM
tweets04's Avatar
Thanks. I wasnt real excited about the gold color, looked like grandma's car. After some tint and painted lights it made a huge difference. Now gonna work on getting rims and doing the rain strips black like I saw on this forum.
tweets04 is offline
Old 06-10-2011, 05:09 PM
Well, it goes good with the color of your car after you slightly tinted it. Honestly only seen one person that kind of went that route but he painted his pebble peach instead.
Looking forward to seeing an update man. You should make a build thread or something. It'll be a nice change of pace on this forum.
Old 06-17-2011, 09:44 AM
dee.signs's Avatar
Wow thanks for all the replies.. Is it pretty simple to pull the HL assembly out and disassemble it??
I was also thinking of doing some Iron Man LEDs, but i hve found some that i believe i could flush mount, so they don't stick out like nipples..LOL..
Old 06-17-2011, 09:46 AM
dee.signs's Avatar
Can i hit you up for some info on that subject too??
Old 06-17-2011, 05:44 PM
Yeah, it's hella easy. The only issue that people have would be re-sealing and getting the proper seal. Which isn't really hard at all. You just have to make sure to take precautions and do it right.
As for the iron man. There's a LOT of things that can go wrong with that mod. Bulbs going out during the modification process. Or a few months down the line for example. Which is why I didn't do it myself.
Yeah man, you can hit me up whenever you have any questions about this mod. I can walk you through the whole thing. It really isn't as hard as some make it out to be. You just have to be patient with it.
Old 06-17-2011, 10:52 PM
tofuproductions's Avatar
Looks great! just seal it up properly.
tofuproductions is offline
04-16-2020 05:15 AM
06-06-2017 02:01 PM
REDinLV
10-18-2015 05:31 AM
Dennis Twohy
10-01-2015 06:01 PM
Noela
09-26-2015 08:22 AM
Quick Reply: 2007 Headlight painting
