Bluetooth problem
Old Aug 19, 2011 | 02:33 AM
Torchcorvette's Avatar
Bluetooth problem
I'm having a prboem with a newly paired cellphone in the 2007 Maxima.
If somebody calls the cell number while it is on bluetooth inside the car, the phone rings twice, then cuts out and stops ringing. If the caller calls back, the call goes right thru normally.
Verizon service told me to go to the dealer. The dealer told me to go to Verizon.
Any ideas will be appreciated.
Thanks.
Old Aug 19, 2011 | 04:02 AM
Kryogen's Avatar
when you hear the first ring, SLAM the bluetooth receiver hard. lol.
Should work.
No clue, really.. :P
Old Aug 19, 2011 | 09:52 AM
KickerMax02's Avatar
Should work.
^^^^ Worthless!
Have you tried going through the menu and delete the pairing and then start over completely. Or maybe your Priority level is set wrong.
All else fails check out this site
http://www.nissanusa.com/bluetooth/
Old Aug 19, 2011 | 10:29 AM
Originally Posted by KickerMax02
^^^^ Worthless!
Could not find the Samsung Convoy on either the recommended or non-recommended lists. Called Nissan. Told me to hard reboot...pull phone battery for 30 seconds...and then delete everything and start over as you suggest.
So, I'll do that over the weekend. Thanks for the response.
Joel
Old Aug 19, 2011 | 10:53 PM
BayRidgeNissan1015's Avatar
itry using a different phoneee...? ECU reset?
Old Aug 20, 2011 | 08:18 AM
Rsprince89's Avatar
Email me. This happened to me on my 08. I have a version iPhone 4 . So I can explain to you on how to fix this. It's going to keep happening tho just to let you know. I can't tell if it's nissans fault or Verizon's ethier. I feel you, they are prob both making you feel like a crazy man lol. that's how they made me feel
Old Aug 20, 2011 | 09:25 AM
email sent. thanks.
viperboy
Sep 27, 2015 07:05 PM
homewrecker
Sep 24, 2015 07:01 PM
Kalrakam
Sep 16, 2015 12:30 PM
