How can I get the pivot bolt loose on the power steering pump?
Old Jun 5, 2012 | 05:33 PM
03blk6mt's Avatar
So, I'm changing the timing chain tensioner and guides on my fiance's 04 Max and everything is going smooth so far, but I'm having a ***** of a time getting the pivot bolt loosened on the power steering pump so I can get the belt off! I've tried a series of 18" extensions to try and access from the drivers side as well as a ratcheting wrench from the underside and can't get it loosened. Has anyone got the infamous secret to snapping it loose?
Old Jun 5, 2012 | 05:38 PM
NmexMAX's Avatar
dot dot dot ...
So there are 2 bolts and the lower one is reversed threaded. Well not really by CCW loosens the bolt the top one allows the assembly to move up and down to tightn or loosen. YouTube the 4th gen version it's the same.
Old Jun 5, 2012 | 05:55 PM
03blk6mt's Avatar
Thanks. The adjuster and the bolt that locks the adjuster are both loose, I'm talking about the bolt on the backside of the power steering pump that goes through the engine block.
Old Jun 6, 2012 | 10:01 PM
acercomp71's Avatar
it is done with 14 mm socket on a offset ratchet. what is offset ratchet? it's a ratchet that has a handle which can pivot up or down. if ratchet handle is too short, slide over a piece of metal tube over handle for extension
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
rnb754
Sep 14, 2015 11:39 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
