2004 nissan maxima lower engine cover replacement?
Old Oct 15, 2012 | 11:45 AM
Harrison Nguyen's Avatar
hey i was wondering what holds the lower engine cover for the maxima in place. the reason is i went over a very high speed bumb and i found that it scrapped the lower engine cover and 2 rivets fell out. the 2 on the right side attatched to the underside of the bumper fell out but i put new ones back in. I was wondering if there should be 4 holding the cover in place? is it normal that the lower engine cover can move around and is abit lose. How many rivets total hold the piece in place?
thank you
Old Oct 22, 2012 | 09:47 AM
JohnnyBlaze's Avatar
Harrison,
The engine undercover takes 4 or 5 plastic push-pin in the front, that push up through the lip on the front bumper. Also, each side of the rear of the undercover takes some different sized push-pins.
Here are the part nos. that you'll need, get under the car and check the no. of holes in the undercover. Also, if you ran over something...I think you enlarged the push-pin holes. When I did that, I replaced the entire undercover and all push-pins. Its a really cheap setup.
1. Cover, Engine under 75890-7Y000
2. Clip, Front Cover (5) 01553-09241
3. Clip, Rear Cover (13) 01553-09321
This info was taken directly from the 2004-05 parts list. Order the parts from www.courtesyparts.com
Hope this help.
Old Oct 22, 2012 | 10:07 AM
Harrison,
Here's an update to my previous post. I've located Nissan service bulletin about these front push-pins. NTB06-022 says replace the push-pins for the front edge of the under cover with these parts.
J-Nut (5) 01241-00751
Screw (5) 01466-00011
Plastic Retaining Clip (4) 01553-0093U
Old Oct 22, 2012 | 10:10 AM
mrjasonlyrics's Avatar
Got pics man?
ah2002
Mar 9, 2016 01:42 PM
District
Aug 15, 2015 08:23 PM
niZ
Aug 7, 2015 10:18 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
