2008 Maxima HID replacement
Old Dec 11, 2012 | 03:14 PM
jknight118's Avatar
Need a little help. My driver's side HID low beam just turned pink this morning on my way to work. I turn the car off for a few minutes and start back up and the light stays its original color for about 1 minute before it goes back to pink. Is it safe to assume that I need to replace the bulb? But I should replace both since I have to pull the front bumper cover off The dealer wants $190 per bulb, is there an alternative that is a little cheaper? A friend that manages an audio store told me he could get me Phillips replacement bulbs for the 08 Max for $125 for the pair as opposed to $380 from the dealer. DOes anyone have any experience with HID replacement and can recommend a replacement for me so I don't spend the kids Christmas money. LOL....
Old Dec 11, 2012 | 03:53 PM
tigersharkdude's Avatar
www.theretrofitsource.com for the bulbs
Old Dec 11, 2012 | 04:12 PM
jknight118's Avatar
Which color would i need that would be closest to the OEM 5000K or 6000K? I'm not really sure which ones I would need. Thanks for your help but I've never had to replace before and don't want to have to do it again. So I want to make sure I purchase the correct thing
Old Dec 11, 2012 | 04:45 PM
joecurr's Avatar
What color light do YOU prefer? If you don't want to spend too much and like a little bit yellowish output, get Philips 85122+, which are a bit yellowish and stay yellowish as they age. If you don't want to spend to much and like a little whiter output, get Osram Xenarc 66240, which start off a little yellowish and get whiter as they age. If you don't mind spending about $200 for a pair, get the Osram Xenarc 66240 SVS or Osram Xenarc 66240 CBI, 4300K and 5000K respectively. You could get whatever color Morimoto 3FIVE bulbs you want, but I prefer OEM bulbs now.
Old Dec 11, 2012 | 05:20 PM
jknight118's Avatar
HID replacement
joecurr, i want to be as close to OEM as I can get. I don't mind spending a little more to get as close to OEM as possible, but I just think $380 form the dealer is ridiculous. So, would the 5000K get me the OEM look
Old Dec 11, 2012 | 06:00 PM
06BlckMax's Avatar
OEM is 4300
Old Dec 11, 2012 | 06:10 PM
2LEET4U's Avatar
Order these and your set. Ive been using a pair for 4 years now and no issues.
http://www.umnitza.com/oe-xenon-repl...d2s-p-100.html
Old Dec 11, 2012 | 06:27 PM
jknight118's Avatar
Originally Posted by 06BlckMax
OEM is 4300
Thanks 06BlckMax
Old Dec 12, 2012 | 04:24 AM
Kryogen's Avatar
I would get those:
http://www.theretrofitsource.com/pro...oducts_id=1250
Morimoto, they say they have less warranty issues with those than OEM.
45$ a pair, thats ridiculous, I paid 200$ a pair at car parts store last year...
Or get philips, 95$ a pair.
http://www.theretrofitsource.com/pro...roducts_id=148
3000K is yellow, 4300K is OEM white with a hint of yellowish (most light), 5000K is whiter (less light), and 6000k is bluish (even less light)
Personally I like 4300K. Most light. The purple and blue color comes from the projector anyway, you do not need whiter bulbs. Whiter bulbs are for hid "kits", when people want to fake the hid reflector colors in a car that doesnt have hid projectors. If you want to fake the hid look in a civic, you need "blue bulbs", at the cost of lower light output, and uglyness.
Old Dec 12, 2012 | 12:04 PM
joecurr's Avatar
OEM will be 4300k, so the Philips 85122+ should be good enough. On the HIDplanet forums, people have compared those with the Osram SVS and have found that the SVS's do provide better overall lighting. The center hotspot is a bit bigger and wider, allowing you to see a bit better down the road, and the sides are also a tad brighter. I'm currently running 85122+'s and they still provide great output, but for me personally they are a bit too yellow. I have Osram CBI's collecting dust waiting to be installed.
Originally Posted by Kryogen
I would get those:
I wouldn't really say Morimoto has less warranty issues than any OEM bulb, but they might have less warranty issues than other aftermarket bulbs. The good thing about Morimoto's is if you do have warranty issues, theretrofitsource has GREAT customer service. And regarding color, using Osram CBI's there no longer is less light when going from 4300K to 5000K. These bulbs offer the best white output in the market, equivalent if not better than most other OEM 4300K bulbs, and definitely better than any other 5000K bulb. Choosing between 4300K and 5000K is really a preference, and with the CBI's loss of output is no longer a concern. Like I said, the 85122+'s provide me some good output, but the color just looks too close to halogen for my liking.
Mrbizness1
Aug 18, 2015 08:43 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
District
Aug 15, 2015 08:23 PM
jomax14
Aug 12, 2015 11:49 AM
silver_i35
Aug 3, 2015 11:20 PM
