Grinding noise that I cannot figure out
Old 10-26-2014, 07:54 AM
97maxima1981's Avatar
I have replaced the wheel bearings, brakes, rotors, calipers, and master cylinder and I still have a grinding noise/slight vibration that can be heard/felt when accelerating or coming to a stop. I have spent hundreds of dollars and I am at my wits end. Any thoughts?
97maxima1981 is offline
Old 10-26-2014, 09:20 PM
chrome91's Avatar
stickshift trans?
chrome91 is offline
Old 11-10-2014, 08:24 AM
died4me's Avatar
Tie rods, end links, sway bar?
died4me is offline
Old 11-11-2014, 06:00 PM
MiaRaider81's Avatar
rattling can be caused from a loose heat shield which ids located on exhaust
MiaRaider81 is offline
Old 11-11-2014, 06:21 PM
po8pimp's Avatar
Have you jacked up the car and spun the wheel free hand yet? If so does it still grind? If that is the case, you should be able to pin point it. It is hard to diagnose noises without sound/video clips and in different situations/environments.
po8pimp is offline
Old 12-01-2014, 09:36 AM
carlosr's Avatar
is it mainly when driving slowly and applying brakes and appears to come from engine area? could be abs pump kicking in prematurely as per the tsb. I had that problem which eventually lead to burning out abs pump which is very expensive and labor intensive to fix.
carlosr is offline
hcarter1112
42
07-18-2022 03:35 PM
D Mason
06-21-2016 04:43 AM
fx4five
10-18-2015 06:57 PM
uttadms31
09-30-2015 05:24 AM
Quick Reply: Grinding noise that I cannot figure out
