Looking to buy 2007 SE/SL 55K $9400
I just came across this really clean 2007 1-owner SE/SL with 55k for $9400. I am looking for a solid reliable car. What are your insights on its cost of ownership for the next 5 years and the short-term maintenance that I should expect? Also at 55K what maintenance should have already been completed at this point? Thanks!
do not spend 10k on a 10 year old maxima
-low pressure A/C hose replaced (June 2012)
-cam & crank sensors replaced (November 2012)
-catalytic converter replaced (November 2012)
-Battery replaced (December 2012)
-Transmission fluid drain & fill at 81,473 miles (June 2013)*
-MAP lamp assembly replaced (June 2013)
-New tires at 87,336 miles (December 2013)
-Replaced brake pads & rotors(December 2013)
-Replaced both Belts (January 2014)
-Rear driver wheel bearing replaced (June 2014)
-Transmission fluid drain & fill at 94,261 miles (June 2014)
-front & side engine mounts (July 2014)
-Replaced front & rear valve covers/gaskets (July 2014)
-Changed spark plugs at 95,089 miles (July 2014)
-Replaced hood struts (January 2015)
-Battery replaced (January 2015)
-transmission fluid drain & fill at 107,160 (September 2015)
-replaced throttle assembly (107,311)
(September 2015)
-replaced rear ignition coils after coil #5 misfired at 110,367 (January 2016)
-replaced spark plugs at 110,367 (January 2016)
trasmadean
Aug 10, 2021 07:14 AM
myaeger18
Apr 7, 2016 08:37 AM
