Power steering issues?
Old Jun 26, 2016 | 12:16 AM
6thGenMaxi's Avatar
Hey guys I have the 6spd 04 model maxi. Light mods. I have randomly and recently been having some tension in my steering wheel lately. Like its power steering going out or something. Wheel just feels not as free. I have no leaks. Full fluids. Anyone else had this issue?
Old Jun 27, 2016 | 09:07 PM
SR20Power's Avatar
Any noise when you turn the wheel? are your tires properly inflated?
Old Jun 27, 2016 | 09:25 PM
6thGenMaxi's Avatar
No noise at all. From wheel or under hood I mean period. And I made sure to put my tires to spec. And same results.
Old Jun 27, 2016 | 09:30 PM
SR20Power's Avatar
On the rack and pinion, there are points where grease can be shot into it.. You car should be put on a lift and checked.
Old Jun 27, 2016 | 09:32 PM
6thGenMaxi's Avatar
Grease fittings. Good idea, just happen randomly though what gets me. Hope pumps not going out
Old Jun 28, 2016 | 03:05 AM
SR20Power's Avatar
Pump is easy to change.. Just can be messy with removing the bolt and the fluid going all over the place.
Old Jun 30, 2016 | 12:00 AM
rcy's Avatar
rcy
There's a u joint on the lower portion of the shaft from the steering wheel. It tends to rust and cause hard turning of the steering wheel. It happened to me...just sprayed a whole bunch of lube onto it and the problem went away.
Search the forum....there are other posts about this.
Old Jul 4, 2016 | 06:11 PM
maximatech12's Avatar
You can get a steering oil pressure gauge the pressure is high 1160-1276psis
Check it follow the precautions before and check the TSBs
Old Jul 4, 2016 | 11:18 PM
6thGenMaxi's Avatar
Thanks everyone. Got the problem fixed. Appreciated
Old Jul 4, 2016 | 11:59 PM
rcy's Avatar
rcy
And???
iTzCloud
Apr 9, 2016 08:06 PM
DeusExMaxima
Apr 8, 2016 11:50 PM
maxima2fst4u
Apr 2, 2016 10:35 PM
pewterss
Mar 29, 2016 05:19 PM
