Crank but NO start?!?!
Old Feb 6, 2018 | 11:18 AM
TMRsuccess08's Avatar
Hello to everyone! I have a huge problem which I hear is common with these VQ35DE engines. I replaced the valve covers both front and rear and now my baby will not start. I tested for fuel and compression and everything is great. Tested for spark and it doesnt seem to have spark at all on ANY of the ignition coils. Upon doing the valve covers, I only disconnected the battery and everything else I pleasantly moved to the side to give myself room. One of the wiring harnesses I moved to the side was the one above the timing cover on my 2004 maxima 6speed. I was careful not to pinch anything or yank on any wires but still no start. Is the wiring harness the culprit? And should I just pirchase an entire harness or find the short in the harness if it is the problem? Any advice would be helpful. Thanks in advance
Old Feb 6, 2018 | 08:15 PM
smittybizzle's Avatar
Are you getting any codes, did you route the harness for the coils correctly? Could be just a bad connection I highly doubt you damaged the harness if you were careful.
Old Feb 6, 2018 | 08:26 PM
The codes I have are for the crankshaft position sensor (the flywheel is missing teeth) which I had for about 6 months now and o2 sensor level high. But I also grabbed and tugged pretty hard on a 3 wire connector (brown in color) that runs in the same harness as the ignition coils and fuel injector connections. I will take a pic tomorrow. I dont know what it leads to, but its routed through the front engine mount.
Old Mar 21, 2019 | 01:51 PM
Tyremathis's Avatar
Hey man did u figure anything out
334 did you every figure out your problem
Old Mar 22, 2019 | 04:42 AM
yes! Unfortunately, it was the clutchplate / flywheel missing teeth and its warped. So there was no constant signal being sent to the computer. Getting the whole transmission revuilt as we speak!
Old Mar 22, 2019 | 05:58 AM
04maximas's Avatar
ya also need to fix that nats issue. it will lock down the whole vehicle
Old Mar 22, 2019 | 06:47 AM
Yes indeed! Once I get my other maxima some tires I will be sending to Nissan to get new keys. These are barely holding together
Old Mar 22, 2019 | 08:21 AM
04maximas's Avatar
ya could always order the blanks on eBay, have pep boys trace the original key to the new one than have a locksmith come out to program them
Violator
Mar 15, 2019 07:54 AM
maxinout93
Apr 30, 2018 08:40 PM
yuriy
26
Oct 3, 2012 02:01 PM
TurboS13Hatch
Jun 19, 2008 10:57 AM
MaximaN00b
Apr 17, 2007 08:16 PM
