Bank 1 fuel injector wire harness
Hello I'm wondering if the fuel injector wire harness is removeable on bank 1. Asking because when I push 2 of them down they don't click like the rest do. I was trying to trace the wire harness but it goes behind the motor and can't really see if it can be unplugged.
If bank 1 is cylinders 1,3,5 then yes. There is a little difference between the 3.0 and 3.5 engines, but it is a smaller section of wire harness. The harness section runs the injectors, the oil pressure sender and a crankshaft sensor. On the 3.0 it is the crankshaft pulley sensor. On the 3.5 it is the flywheel sensor. It plugs into the main engine harness in the area of cylinder 1 above the valve cover. It is an 8 pin connector, I think blue color.
You might want to consider cutting the fuel injector connectors off a junk yard car and soldering (not crimping, not twisting, not wire nut) on to your harness.
Whtmax'01
05-27-2012 05:55 AM
95CustomMaxima
06-15-2005 12:55 AM
1MAX2NV
09-24-2001 06:50 PM
