Putting the Timing Cover Back on
Old Apr 18, 2018 | 05:29 PM
icecoldzoe's Avatar
Hey guys,
I just finished replacing the timing chain, tensioners, etc on my 06 Maxima, and I'm running into problems re-installing the front cover. I've already went through a tube of Super black rtv, because for whatever reason, I can't get the bottom seal to sit properly! it's driving me nuts!!!! I tried searching the forums to see if anyone else had this issue, but couldn't find an answer. If I sit the bottom of the cover (with the rubber seal ) on first, then I can't get the pegs on the sides of the cover to line up, and vice versa if I line up the pegs. Any tips, suggestions, VIDEO of someone putting it on (Youtube has NOTHING) would be great. Thanks in advance!
Old Apr 18, 2018 | 07:43 PM
L_U_D_I_AMaxima's Avatar
what seal are you talking about? If I remember correctly the front seal does only has liquid sealer on it.
Old Apr 18, 2018 | 07:53 PM
icecoldzoe's Avatar
It's the U-shaped gasket that sits on the bottom of the timing cover. There's a small notch to connect it to the cover, but it keeps moving
Old May 9, 2018 | 10:14 PM
smittybizzle's Avatar
I'm pretty sure you figured it out by now but its the half moon seal. You have to tilt the cover downwards, its a pain while in the car.
Stormzusmc
32
Feb 27, 2009 05:20 PM
Driven EF9
29
Jan 22, 2004 04:08 PM
2k1maxgle
Dec 12, 2002 12:56 AM
ptatohed
Jul 24, 2001 12:17 AM
Jeff2k1GLE
May 25, 2001 04:09 PM
