Service engine soon light
Old Aug 31, 2018 | 10:56 AM
Tamburitzan's Avatar
i have a 2005 maxima. The service engine soon light is always on. The fault codes display an error with the mass air flow sensor. I have changed the A/F sensor numerous times and cleared the fault codes. The service engine soon light comes back on with an A/F sensor fault again. I have cleaned/changed the air filter and made sure the air ducting is connected.Any suggestions?
Old Aug 31, 2018 | 12:13 PM
Davisnathan49's Avatar
Have you checked the wiring to the harness/plug? Could be a loose wire. Check the wires for any damage.
Old Aug 31, 2018 | 12:31 PM
Wires seem to be in good shape. I also cleaned the contacts. Thank you for your response
Old Sep 2, 2018 | 01:09 PM
Costee's Avatar
Are you getting an error for the MAF or A/F? What exactly is the code?
Old Sep 2, 2018 | 01:44 PM
Thank you for responding
it changed from MAF to A/F. I did the relearn procedure for the ECU
Old Sep 3, 2018 | 02:14 AM
Costee's Avatar
What was the precise code?
Old Sep 3, 2018 | 04:43 AM
P0101. MAF sensor replaced. Then p1273. Mixture relearn procedure done. SES light goes out for a few days. Then fault codes above return
Old Sep 3, 2018 | 05:51 AM
Costee's Avatar
Check for tiny leaks around the A/F sensor and manifold area.
Old Sep 4, 2018 | 03:47 AM
edjose17's Avatar
Usually a dirty throttle body will cause this code.
Old Sep 4, 2018 | 03:57 AM
Costee's Avatar
I doubt, and any attempt to clean it is most likely to open up fresh issues.
Old Sep 4, 2018 | 09:24 AM
Thank you all
Old Sep 5, 2018 | 04:21 PM
Throttle body
Would a faulty throttle body cause this problem? I do have a new one I thought about installing
adsinclair
Mar 22, 2013 07:12 PM
Louie Max
Apr 29, 2007 06:29 PM
BIGHANK
Feb 11, 2005 12:19 PM
a33
Nov 22, 2001 07:49 PM
2THEMAX
Oct 20, 2001 03:12 AM
