Other reasons for power steering leak
I have read about the leaking high pressure hose. Could it be something else? Could the pressure switch crack and leak? Could the switch come loose and leak? Could the bolt holding the hose on the pump come loose? Maybe a crush washer?
I plan on pulling the cover back from the hose and seeing if fluid id coming from there. Just covering all my bases.
Thanks,
Ken
Thanks,
Ken
Loosen one of your tie rod boots and see if it's got power steering fluid in it. This was a surprise to me the other night and, from what I've read, it could be a leak in the rack and pinion seals.
The seals on the p/s rack can leak.
Mine did and had to be replaced recently. Along with the pump and high pressure hose.
If you have them replace the rack just have them do the high pressure hose too. I didn't because the mechanic told me it was fine, but when I got it back with the new rack and pump, it had developed new leaks where it crimps to the metal end.
Thanks,
Ken
Thanks,
Ken
Montego Murph
11-14-2016 11:11 PM
tcaughey
09-10-2010 11:57 AM
MoonKnight
08-11-2003 02:51 PM
