My 2004 Maxima stearing wheel is shaking (vibrating) when driving at 80 - 100
Old Aug 24, 2019 | 08:57 AM
Gytis Garbačiauskas's Avatar
I bought 3.5 se maxima 2004, 195 kw. There is one problem with my stearing wheel at 80 - 100.. Where is the problem? Tyre balance, warped plastic down the radiator or wheels alignment? And plus I want to ask how much oil (in litres) I need to buy for my maxima for engine and how much oil for transmision. Thank you!
Old Aug 24, 2019 | 08:22 PM
NC00DEK's Avatar
Could need a tire balance, or you could have flat spots on one or more tires.
I actually broke a belt in one of my goodyear touring a/s tires and it definitely caused some shaking at higher speeds before a tech found a slight bulge in one of them. It was especially disappointing because it still had a good bit of tread left
Oil capacities
I'm not sure what transmission you have, but you should consult the owners manual if you have it.
Old Aug 25, 2019 | 04:33 AM
Thanks a lot I will chek this. My transmission is cvt
Old Aug 25, 2019 | 05:15 PM
steve89052's Avatar
Try a wheel alignment
Old Aug 26, 2019 | 07:15 AM
Tarzan's Avatar
You can rotate tires from front to rear and see if the vibration follows before rebalancing them but I would balance them anyway.
Is there more shimmy when braking from the HW speed? If yes, then your rotors warped.
Old Aug 26, 2019 | 08:05 PM
User1's Avatar
Is that Slavic?
Old Aug 27, 2019 | 07:17 AM
Tarzan's Avatar
No, that's Lithuanian. Different people, different language group.
Smoothieking
Feb 4, 2010 10:52 AM
Jerry13
Jan 4, 2004 07:22 AM
Superman
Dec 26, 2003 07:40 AM
stephenlc
Jan 13, 2003 05:50 AM
sgera
Sep 3, 2002 09:04 AM
