Paraasitic Load Testing - Battery Keeps Draining
Old Oct 3, 2019 | 09:57 AM
adpostel's Avatar
What is the normal parasitic draw on these Maximas? I have my multi-meter on the mA setting and I have it between the negative battery cable and the negative post of the battery. It is reading 1.75 mA , but I'm not sure if that is normal or not. My new fully charged battery will drain to nothing after sitting for 2 days. So just trying to figure out why it drains so quickly. Any help is appreciated.
Old Oct 4, 2019 | 07:37 PM
User1's Avatar
<50mA.
Post a picture of your meter display while hooked up.
Old Oct 5, 2019 | 05:11 PM
User1's Avatar
I posted a good video from Eric the Car Guy on another thread. It's a good procedure, but here's another video with a similar, yet simpler and more accurate method:
Old Oct 5, 2019 | 05:19 PM
User1's Avatar
Keep in mind that if you have a drain that kills your battery within 24hrs or so, the drain will be very apparent with the meter in series method as evidenced by high mA. Then to isolate and identify the exact source, I would use the above method. There are lots of ways to diagnose shorts, these are just two good videos of proven methods to help wrap your head around the process.
Here is the Eric Car Guy video using meter-in-series method:
Old Oct 10, 2019 | 05:59 AM
Roymg's Avatar
If lamp switch was left on, there should be a internal light on?
nelgin
Jul 29, 2019 12:43 PM
mmunster
Mar 9, 2014 08:18 PM
silvermax2k2
20
Sep 25, 2006 03:26 PM
maxperformance
May 9, 2002 10:56 AM
