Timing change replacement
Old Nov 10, 2020 | 12:52 AM
Tamburitzan's Avatar
I have a 2005 maxima with 182,000 miles on it. I took it to a Meineke place for an oil change and I was told that I should (not need - no noise) replace the timing chain. I have either used Mobil 1 15W-50 synthetic oil or Castrop 5W-50 the entire life of the car. What to y’all think? Do I need to replace it or is Meineke just looking to make $2000+? Thank you
Old Nov 10, 2020 | 01:15 AM
aackshun's Avatar
OEM timing equipment is HOT garbage on the 6th gen.
If its not making a peep at any point in time then everything is actually fine (for now).
In my personal experience you have warning clicks and rattles before the tensioners and guides calls it quits and cause real damage.
So pay very close attention to any noises on startup, especially cold starts.
If you're close to Houston I can overhaul the motor for 800 + parts (look around 1500 total) *shameless plug*
Old Nov 10, 2020 | 06:58 PM
ironman187's Avatar
If OEM are garbage, who makes good ones?
Mine started the death rattle this weekend after an oil change (of all things), so I'm getting things lined up to replace the tensioners, water pump, and probably the chains.
Old Nov 10, 2020 | 07:48 PM
aackshun's Avatar
You must purchase the oem timing equipment for a 03-06 350z (non rev-up for 05/06 years)
It's not the same (It's sad) and it's cheaper and better made (Even sadder).
Old Nov 10, 2020 | 08:52 PM
Thank you. Does the entire engine need to be removed? Are there any after market parts that are better? I want to keep mine because it is the 6 speed stick shift. Manual transmissions in decent size sedans are becoming extinct
Old Nov 11, 2020 | 03:45 AM
ironman187's Avatar
Wow, why would they do that? Is there a comprehensive list somewhere of parts one needs to do the job? Also, are the 350z stock parts the way to go, or are aftermarket fine?
Old Nov 20, 2020 | 12:38 PM
ironman187's Avatar
Sorry for the double post, but my chain rattle is getting worse, so I need to get moving on replacing it.
Does the following parts list look right to you?
1x Part No.:13085-JK20A
GUIDE-CHAIN,TENSION SIDE
$17.46
1x Part No.:13091-JK20A
GUIDE-CHAIN,SLACK SIDE
$47.08
1x Part No.:13070-EY00A
TENSIONER ASSY-CHAIN
$70.49
1x Part No.:13085-AL511
GUIDE CHAIN TEN
$9.91
1x Part No.:13070-8J14C
TENSIONER CHAIN
$73.35
1x Part No.:13028-JK00A
CHAIN-CAMSHAFT
$94.17
2x Part No.:13028-JK20B
CHAIN-TIMING CAMSHAFT
$193.06
1x Part No.:13070-8J14D
TENSIONER CHAIN
$73.35
1x Part No.:B1010-AL50B
PUMP ASSY-WATER
$116.10
Part No.:13510-7Y000
SEAL-OIL,CRANKSHAFT FRONT
$16.79
2x Part No.:15066-ZL80A
SEAL O RING (6.84MM)
$12.22
TOTAL w/ shipping & tax $803.33
Old Mar 15, 2024 | 05:57 PM
dr bob's Avatar
how did that repair go? I am looking at the same thing and thinking of junking the car.
ShunDoe
Feb 22, 2016 10:37 AM
delacruz_17
May 26, 2013 05:41 PM
Daniel 91 SE
Dec 4, 2002 11:51 AM
Yossarian
Jun 1, 2002 07:33 PM
AgisAbatzoglou
Apr 20, 2002 05:33 AM
