04 maxima engine trouble
Old Dec 14, 2020 | 06:20 AM
Theiceman447's Avatar
Hey guys, i have an 04 maxima sl and recently it started smoking when it runs. Shortly after that it started blowing the dipstick out of the dipstick tube and spraying oil everywhere. Obviously there was something causing a lot of blow by so i pulled the intake and did a compression test. The results were: front head (left to right) 80psi, 50psi, and 35psi. Rear head(left to right) 185psi, 145psi, and 150psi. My main question is what would cause all 3 cylinders on the front head to lose compression?would it be a bad head or do i just have bad rings? I find it strange that only one bank has bad compression and the other one is fine. Also I'm looking for info on how to get the valve springs off so i can check the seals. Thanks in advance for any help and if more info is needed leery me know. My car only has 128,xxx miles on it.
Old Dec 14, 2020 | 04:54 PM
aackshun's Avatar
Ok no matter what the head has to come off.
Sooooo...... Take that head off.... go from there. You can check vacuum on the valves to see if a valve job is needed. Or you can see if pistons rings are failing too at that point in time (ringed wear marks on the cylinder walls).
If you're doing that much work I'd just pull the motor out and swap it.... But good luck!
Old Dec 14, 2020 | 05:32 PM
yeahhh that's what i thought but i figured i would ask mainly to see if there was some sort of common problem. maybe bad valve seals or bad rings are common on that particular head. I agree about swapping the motor being the most likely play. Do you happen to know if jdm engines are plug and play? I see a lot of them advertised on the interwebs. No matter what, thanks forthe reply bro, i appreciate the input.
Old Dec 14, 2020 | 10:06 PM
Ogdatsun80's Avatar
Swap candidate
https://dallas.craigslist.org/dal/ct...240753377.html
can 09 7th gen motor be swapped onto 6th gen manual car?
GuppyMaximaOnDubs
Nov 11, 2014 07:38 PM
Max-Maxima
Jan 24, 2013 02:34 PM
kahasima
Jul 31, 2012 05:21 AM
blinelaxd27
24
Oct 15, 2010 07:08 PM
sitnonchrome76
Mar 29, 2004 06:04 AM
